Vizio Tv won't stay on
I have a Vizio W26L10 HDTV. I cut it on and it will stay on for about ten seconds, then the screen goes black and no sound. I've check they cable and they seem to be conected ok.
SOURCE:
  • 6 Answers
SOURCE: Screen goes blank / black, sound still works
It sounds like your LCD Screen is no longer working. I would try contacting Sony and ask for a refund. I had the same T.V and the LCD Screen had gone out. A techniction came out and Condemned the screen and i had to pay $500 for a new T.V.
Posted on Apr 14, 2009
SOURCE: Vizio 50 inch plasma tv has no picture and no
check the Y-sus and Z-sus board
Posted on Nov 02, 2009
  • 76 Answers
SOURCE: Can I safely use my new Vizio HDTV on regular cable ?
you may try...and you might surprize if it works then no need of the cable guy...
Posted on Dec 31, 2009
SOURCE: TV Has Sound but no picture
Change or move yellow one, of the cables, or component. if not then something you need from expert..
Posted on Jan 02, 2010
FixinFax
  • 3085 Answers
SOURCE: Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
Posted on Jan 21, 2010
Vizio tv model e420vse turns on and then screen goes black. Still has power and sound. If I turn off and back on, the picture will come back for a few seconds and then shut off again. Vizio suggested it...
There are a lot of references on how to repair the LED backlight. If you can source the parts, google search LED backlight repair.
You may wish to read this first: http://www.techlicious.com/blog/un-repairable-vizio-tvs-leave-customers-out-of-luck/
Mar 31, 2015 | Vizio E420VSE 42" 1080p 60Hz LED LCD 2.4"...
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
Vizio 47" screen won't stay on
Your Vizio TV may be exhibiting symptoms of power supply trouble even though it is quite new.
Dec 01, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
I hae a vizio E320VL, i have replace main board and the power suplly, and it still won't stay on.
hi. you sure your replacement -- power supply & main board in good condition???? lcd present 5v , 12v, &24 v ??? if no you need going back power supply. if yes. you need to replace inverter board as possible. good luck!
Sep 01, 2012 | Vizio L32 32 in. LCD HDTV
Tv has power but when i turn it on it clicks like its going to come on but screen stays black. One of the led lights is blinking(led2002) the rest stay on.
bad caps inside tv can be fix if you get the right person for less than ten bucks in parts there is like 50 or so power caps in there you to look for the one that is popped out
Feb 06, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio LCD HDTV Screen is Black No Sound help
Not to be a smart alek but buy a new tv
Jan 04, 2018 | Vizio VX37L Television
Lightning strike
press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code.
Jun 10, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
730 people viewed this question
Top Televison & Video Experts
Ekse
