Question about Acer Aspire™ T180 PC Desktop
Help when i power up my computer i hear a single beep i then get a white screen with an acer background it says in the left hand bottom corner of the screen DEL:ENTER SETUP and in the right hand bottom corner F12:BOOT MENU but wont let me do anything from there av only had the computer 2 weeks and cant get anywhere with it any help is much apreciated
  • bigbaz Mar 15, 2008
    ok checked everything al seated correctlypowered up no-go check ed keyboard and mouse for correct operation with 2 new units any other ideas i can try anyone
    Guru:
  • 377 Answers
Hi bigbaz
maybe its hardware failure caus, open your case, and find the cmos jumper, clear the cmos with move the jumper to pin 2,3 and power on, after that power off, and back the jumper again .
close case
and power on again
i hope it can solved your problem
thx
cropp
Posted on Mar 16, 2008
    Sergeant:
    Champion:
  • 326 Answers
Turn power off.
Open case and check the connections to ensure they are all plugged-in. Check that all cards are neatly seated into the MB.
Sometimes the cards and connections can come loose during shipping.
After checking those things, power up and try it again.
If no-go, then press the delete key to enter setup and check what it is seeing for hard drives. Prior powerups may have blown out the drive.
Posted on Mar 15, 2008
  • Rory Biggs
    Rory Biggs Mar 16, 2008
    Did U get any results from the Delete key?
Diagonal lines at 45 degree angle from left top to right bottom of screen
db:: 4.31::Diagonal lines on tm2 screen? fz - Hivmr
www.hivmr.com/db/fzap9jk8dp87mcjk3cc9jsp7fzxk7pz1
There are faint 45 degree diagonal lines covering my brand new tm2 LCD ... with some static looking diagonal lines going from bottom left to top right. .... DB:3.01:Dv6113 Us - Computer Freezes Showing Diagonal Lines On Screen aj ... Also there arediagonal lines that run across the screen at about a 30 degree angle.
3M Privacy Filter for Laptop diagonal-14.1" viewing screen ...
www.amazon.com/3M...diagonal-14.../B00006B8A9
Amazon.com, Inc.
Rating: 3.8 - ‎1,617 reviews
Amazon.com: 3M Privacy Filter for Laptop diagonal-14.1" viewing screen ... Premium 14.0 Inch Privacy Screen for Widescreen Laptop or Computer Monitor .... 3M™ Privacy Filters create a 30-degree cone of vision so on-screen data is .... You'll also notice a large "3M PF14.1W" printed in the top right hand corner of the filter.
FZ190: Faint Diagonal lines on screen? ' NotebookReview
forum.notebookreview.com > ... > VAIO / Sony
Jan 27, 2016 | Computers & Internet
Acer touch screen has white bubbles
Try another regular screen to see if it does the same thing and letme know :)
Sep 06, 2014 | Acer Computers & Internet
Turnin on computer blank screen with white dash left hand corner
yah system is not recognizing yah HDD, or a memory stick in the usb ports, so consider ejecting the pendrive and try again, else you need to switch bus cables and jumpers on the HDD. At one point the HDD is dying off and posseses bad sectors hence holds the reader back from reaching sector for data.
#Newtoxtonia
Jan 05, 2014 | Acer Aspire Z5600 Z5610 Z5700 Z5710...
I have no voice at all, how wood i get my volum ajusted.
Hi!
1. If it is visible, single left click on the 'Show hidden icons' button, which is usually located near the bottom right hand corner of the screen. 2. Single left click on the 'Volume' icon, which looks like a gray speaker.
3. Single left click and hold down on the slider in the 'Volume' dialog box. As you are holding down on the left mouse button, drag the slider up to raise the volume or drag the slider down to lower the volume. When you let go of the left mouse button, you should hear a tone to give you an example of how loud the volume is now set. 4. Single left click on the on the blue 'Taskbar' to make the 'Volume' dialog box disappear.
Hope this helps. :)
Apr 16, 2011 | Dell Dimension 2400 PC Desktop
What keys do i press to reboot acer aspire notebook
i have an acer aspire 3680 laptop when i switch it on the power indicator os on but i cant get past a black screen with a small white line in the top left hand corner please help
May 27, 2010 | Acer Aspire 3680 Laptop
My Acer Apsire 5100 will not power on properly. The acer screen (white and blue screen) will almost progress fully. Then, you hear two high pitched beeps and an error screen that says: "system bios...
Your operating system has been corrupted. At this point, you have to get all your information transferred onto another computer and then do a clean installation of the operating system of your choice.
Jan 18, 2010 | Acer Aspire 5100 Notebook
When I turn my PS3 on, my background screen appears but nothing else loads, not even the numerous areas (Settings, network etc.) all that appears is an icon in the upper right hand corner saying "Press the...
you can try doing this cuz i had the same problem till i did this...Access the PS3 recovery menu
1. Turn off Playstation®3.
2. Hold The power button down; The system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be promted to plug in your controller via usb and then hit the PS button
6. The Recovery menu will pop up.
..I did this and i got my ps3 Back !! :)
be patient and wait for those beeps.. they are important
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Screen lines on MacBook.
Sounds like dropped pixels.  My first guess is the computer has been dropped on its corner, with the pixel dropout radiating diagonally from the corner.
My saint bernard sat on my g3 lombard, and I have vertical pixel dropout because of it, from the top of the screen to the bottom.
And no, it is not normal for a macbook to have lines across the screen.
Linda h.
Mar 19, 2008 | Apple MacBook PC Notebook
Accidently locked tv
gonk,
Sorry but you're going to have to be a bit more specific than that.. What kind of Tv is it, what model number, is it the original remote, do you have an otherwise good pic and sound, do functions (vol, ch, power) on the Tv work???
Bill
Dec 11, 2007 | RCA 20F514TD 20" TV
Acer Aspire™ T180 PC Desktop Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
