Question about BenQ PB6110 Multimedia Projector
Benq pb7220, can't find composite video source
I have just recieved this projector from ebay, it came with a new bulb because the old one was at it's life end. I tryed out the projector before replacing the bulb, just out of interest, and it worked fine. I have just replaced the bulb and it powers on OK and I have reset the bulb life, but it can't find a source now.
  • 563 Answers
Hi there
You'll see at the back of this projector where the composite input is there is two holes with screws. Unscrew it and remove the part.
It looks like a DVI connctor. Check if all the pins is in order. If you can't see anything wrong - buy just that part and replace it.
It is VERY cheap to replace.
Posted on Mar 26, 2008
My HD80 has about 700 hours, original bulb assembly, was working fine until I got curious and "activated" the auto off function while going through the menu. Now it will power up, lamp does not go to
Ensure a video source is connected to the projector (VGA, DVD, etc)
Unplug the projector to make sure it has completely shut down (not just went into sleep mode)
Plug in power and power on the projector (make sure video source is on first)
The projector should turn on and switch to the video source (manually select if not)
Once you can see the video source, push menu and turn off auto-off.
Auto-off should only work when the projector detect a video source is no longer present on the selected input. So if you are turning on the projector with no video source connected, it will usually turn off shortly after being turned on.
Nov 30, 2014 | Optoma HD80 Projector
Dear Sirs, I have a BENQ PE8700 projector. I know it's outdated, but it still suits me fine. I've already changed the lamp, and this new one is 1000 hours old. I am recently having a problem:...
If the bulb on this projector is filament less then it may be a bad ballast. If it is that kind of a bulb the ballast is like the starter on a florescent bulb that excites the internal gases for light to be emitted. If it conks out, the bulb stops emitting light even though the cooling fan stays on.
Apr 30, 2017 | BenQ PE8700 Multimedia Projector
Need new adaptor for benQ FP951......because the old one broken....thx
A quick search on Google for "fp851 adapter" turned up several sources. Here's one listing from eBay, which is always a good place to check. If you're not in the US, you can check eBay listings in your area or find an online source that will ship to you. You shouldn't have much trouble locating a replacement.
Jun 02, 2011 | BenQ LCD Power Adapter for FP951 Monitor
How do I thread the film through an 8mm B&H Projector
http://www.folkstreams.net/vafp/stream.php?id=97
It's about four and a half minutes long, and shows how to clean the various components that need cleaning beforehand as well as how to thread the projector.
However, I wish you good bloody luck on finding a bulb, if you don't have one that still works. From the look of the unit, it uses a DAR bulb, which was delisted (read: went out of production) thirty years ago. You can sometimes find new old-stock (NOS) DAR bulbs on eBay, but expect to pay $30 to $35 apiece plus shipping for them.
Sam
Feb 23, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
WHITE BLANK SCREEN
Hi My name is Vortash .. may i suggest that for the price you would pay for a new card you could get a new projector off Ebay or Amazon that just needed a bulb at a fraction of the cost .. regards Vortash
Feb 22, 2009 | BenQ PB6100 Multimedia Projector
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
BenQ PB 6100 .. blue hue on everything !
Most likely (90% sure) you need a new Main Board.
This Board is for sale on Ebay... http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170296659472
Nov 08, 2008 | BenQ PB6100 Multimedia Projector
I've fogeten my password for my benq projector
you may try all "0000" first and then let me know if that worked. Good luck. Jay
Jan 31, 2008 | BenQ PB7220 XGA DLP Projector Multimedia...
Projection display dark on left side
It sounds as if your light tunnel has come loose and most of the time it has to be repaired by a technician, Like myself or someone in your area. I am new to this site and thought i would try out my skills here and see if i could help some people. Let me know if that helps. You can also ship it to me and i can take a look at it and evaluate it for you. I repair projectors for " Luckstrike here in Louisville, Kentucky. email me if you need more info or call 502-773-7969 and ask for Jay
Jan 03, 2008 | BenQ PB7220 XGA DLP Projector Multimedia...
BenQ PB6110 Multimedia Projector Logo
95 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
