Question about Refrigerators
Kenmore refrigerator model # 596.71813101
Is there anyway to adjust the back wheels on this unit?
    President:
  • 1,314 Answers
No you shouldn't need to if its unleavel there push the cabinet to one side and have someone slide a piece of wood under it then adjust the front
Posted on Mar 15, 2008
2 Suggested Answers
  • 20 Answers
SOURCE: Refrigerator Model 596-65232403 2 Yrs old
Ed, check your freezer gasket..it may be partially frozen or torn..RDS
Posted on Apr 23, 2010
I have a Kenmore side by side refrigerator, model number: 41212100. Do you know if this model has wheels? I wanted to clean in the back of the refrigerator, but am unable to move it.
any large side by side I have owned or worked on has wheels . they do however want to sink in /stick and might require a bigger shoulder to move .
Sep 30, 2016 | Kenmore Refrigerators
How to level Kenmore side by side model 596.50004100?
Using a bullet level, placed on top, side to side, adjust the leveling legs front and rear so that the unit places the bubble in the exact middle. Then, placing the level front to back, adjust the front only leveling legs to where the bubble in the level is only half showing in the middle. This will allow the doors to close by themselves.
Oct 09, 2014 | Kenmore Refrigerators
Kenmore refrigerator moves when we open the doors
If you take off the front grill, you will see two adjusting feet to level your unit which also locks the unit in place.
Jan 31, 2012 | Refrigerators
HOW TO ADJUST THE FRONT WHEELS ON A KENMORE REFRIGERATOR MODEL 970C607228
You need to take off the front bottom grill and then you will see the screws to adjust.
Jun 13, 2011 | Kenmore Top Freezer Refrigerator
Where are the leveling wheels located on model #FRS26H5ASB4, side by side refrigerator/freezer. Manufactured by Frigidaire.
The wheels located in the back of the unit cannot be adjusted and the front ones can be accessed under the doors by pulling off the grill assembly. Use the screw going thru the cabinet on each side to adjust the front two wheels. Hope this helps.
Jan 31, 2010 | Refrigerators
Open door and whole unit moves, it dosen't come with back legs, or does it??
No most don't have rear legs. However, they usually will have front legs that screw down past the wheels/rollers to prevent it from sliding around under normal conditions.
You may have to remove the grill in the front (if present on your model) to adjust the wheels/rollers "up" out of the way while lowering the legs to level it, and they should also act as "brakes" to a degree if the floor/surface is relatively level.
Hope that helps,
Good Luck
Oct 31, 2009 | Kenmore 60721 Refrigerator
Freezer door opens each time we close refrigerator door
This is an easy one to fix - at the bottom of your unit you have 2 adjustable wheels you can turn to raise or lower the unit. What you need to do is turn those clockwise which will raise the front - what you want is to have it slightly tilted to the back. As a test you can open your door 45 degrees and leave it - it should be able to close on its own.
Sep 25, 2009 | Kenmore Refrigerators
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
631 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
