Question about Hitachi (AU-160GBSATAHDHIT) 160 GB SATA Hard Drive
FreshGear USB Portable Hard Disk Drive
Help! I bought the above at Changi Airport. Just got it out of the box but there are no instructions. I am pretty computer illiterate and can't figure out how to use it. There is the box, the wire connectors and a small CD. What do I do now??
Annmarie Brazier
Ah! i just followed the advice of putting the mini cd in my computer but I've got a MacBook and I think its just eaten the cd ( i don't think the slot was meant for mini cds!) How do I get my Hard Disk to copy all my files and how do I get this cd out of my computer!!
  • Anonymous Apr 15, 2008
    I bought also at Shangi Airport a Feeshgear without documentation and the CD supplied with it is Windows 98 based.
    I have 2 questions:
    - how do we close down this shop
    - I cannot find anywhere on the net XP based drivers.
    Who can be of help??
    Frans
  • Anonymous Mar 10, 2009
    there's no XP driver for this. it worked without any driver installed the first time, then suddenly it did not work.
  • 30 Answers
I am assuming that this is a laptop, getting the disk out, if you flip you laptop over on the back,under the dvd/cd drive you should see the screws, slow take them off and the drive pull out, dont pull it too far,just enough to take the disk out and re screw it back together,
i am not sure it this hard disk is for made for mac only or what, but try to go on line,search for the driver for this model,download, and it should work good luck
Posted on Mar 15, 2008
What do I do to get started with my new 97060 500 gb Clon portable hard drive?
Plug it into the computer via the USB cable that should provided in the box. There should be instructions in the box telling you this however.
The bigger end is the USB and I presume the smaller end is probably a mini USB connection: Like This
Jun 24, 2011 | Verbatim Smartdisk Clon Portable 97060...
How do I use your Verbatim? Please give me instructions
From Verbatim "Installing your portable hard drive is extremely simple - just use the included mini-USB cable to connect your hard drive to any free USB port on your computer. On Windows computers, a new icon will appear in My Computer representing your hard drive. On Mac OS systems, your hard drive will appear on the desktop as a new disk."
Jun 11, 2011 | Verbatim 320GB USB Portable Hard Drive
Seagate Portable 250 GB External Hard detected for only 2 secs
u can try some hit and trial...
1 - keep ur USB HD off and switch on the PC then switch on the power on USB HD
2 - try another USB port
3 - try another USB cable connector
4 - check ur Device manager/usb root hub settings/power setting, uncheck the box that says" alow computer to switch off power....in Power Mgt tab
Feb 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
External drive not recognized
If the drive is new and you do not see it as a drive in my computer in may need to be initilized and/or partitioned.
Click Start, then Right click on My Computer and click Manage, then click Disk Management. See if your external drive shows up in the list. If it does, right click in the box on the left to see your options. if it needs to be initialized choose it in the list. Then right click on the larger box on the right and choose Partition as the option and follow the instructions given.
Jun 15, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
Maxtor Basics external portable hard drive not getting detected
Right Click on My Computer, click on Manage, go to Disk Managment, if the drive is available you will see it there. Check to see if it has a drive letter assigned to it, if not right click on it and choose Change Drive letters. Make sure you are on the external drive though, you don't want to change your C drive accidentally. It should pop up in My Computer.
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
New verbatim 160gb usb external hard drive model # USB160 isnt recognized by my pc.
I had a simliar problem. This is how I fixed it in XP;
Remove any attached external devices except the one having the
problem.
Go to:
1. Control Panel
2. Administative Tools
3. Computer Management
4. Under Storage right click on "Disk Mangement"
5. The bad drive should show up as Disk 1 with a black bar across
the top.
6. Right click on the bar.
7.Select " change drive letter and paths " and follow the instructions.
8. If number 7 does not work, go back to the menu and select
"Format". During the FORMAT I believe you will be asked to assign
a drive letter.
9. GOOD LUCK
I acutally had this problem with two different drives. I fixed the first one using the instructions above. But the second drive didn't even show up in Disk Management. I had to return it for a new one.
Nov 21, 2008 | Verbatim 160GB USB FireLite: The "drive...
Can you help me please
Thankyou for your reply SirDrag, I have tried the above, my daughter is helping me from her end, we are going to try disk director suite to see if it will pick it up, and units light comes on and I can feel it going, but it does not register on the PC, it says new found hardware on the laptop and nothing comes up. It does not show anywhere. We will try the disk director and see what happens, or I might just have to send it back, my daughter thinks that it might have to be formatted.
Let me know if you have any other ideas, again thanks
regards mollysmerlin
Jan 14, 2008 | Hitachi 120GB Hi-Speed Mobile Disk USB 2.0...
Put the Cd into your computer to install the software application onto your system and follow the basic instructions. You would probably then have to then connect the hrd disk drive.
Nov 27, 2007 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Hitachi (AU-160GBSATAHDHIT) 160 GB SATA Hard Drive Logo
450 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
