Question about Dishwashers
Dishwaher to have a dishwaher installed do you just use your existing pipes that your washer uses
  • 833 Answers
Generally, you need only hot water. It is advisable that the drain line be a little lower than used by a washer. Drains usually go into a modified portion of the sink's j bend in the drain. This sits at about 18 inches off the floor. You should fuse your electric line for 20 amps at 120 volts or 15 amps at 240, depending on your location. North American units are at 120.
Posted on Mar 16, 2008
How do I get rid of white residue on dishes in dishwasher?
if its hard ? then its minerals in your houses water , install a demineralize filter on the washer line , if it flakes off with your finger nail then its left over soap , your using too much or your water pump needs cleaned out or replaced
Aug 15, 2016 | Kenmore Dishwashers
Water does not pump out of dishwaher
is there something stuck inside the water out pipe, or is there something blocking the water from geting out from the washer?
Jun 01, 2008 | GE Dishwashers
After dishwaher cycle complted water still remains
There is possibly a partial blockage in the outlet, preventing the water from draining out in the preset time. Remove the bottom strainers plates and make sure that there is nothing obstructing the outlet pipe and the pump or the selector valve. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 26, 2011 | Dishwashers
Ge FRONT LOADER WASHING MACHINE DRAINS TOO FAST AND IT OVERFLOWS OUT OF THE DRAIN PIPE ONTO THE FLOOR. IT HAS 1 5/8" DIAMETER DRAIN PIPE. SOLUTIONS???
Yes, the new front loaders do drain much faster...I find that you need to have a 2" drain for them to work properly without over flowing the standpipe.
Now, what can you do??
You can add on to the standpipe and get it up higher, this will do two things... the higher lift will slow down the pump a bit, but will make it work harder and possibly fail quicker...the higher stadpipe will give you a bit more reserve space for the water to collect and then flow down and catchup after the intial burst of flow from the pump. The higher pipe will also create a bit more pressure to push the water down the pipe.
The next and better fix would be to install a bigger standpipe and trap. Go right back the the main line and run a new 2" line and trap to the washer.
I assume that you checked the existing pipe and trap for blockage....but thought I better throw that out there...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 02, 2009 | GE WSXH208A Front Load Washer
DO I NEED AN EXHAUST FOR THE WASHER?
The drain pipe must be repaired or you will have water in the house when you use the washer.
Nov 13, 2009 | Ovens
The rubber on the washer is getting this sand-like film on it. Why am i getting this?
If there is sand or sand-like sediment in the washer and it did not arrive there from any item(s) washed in it prior, it arrived via the water supply. This means it came from either the water supply or from the pipes in the house, if the pipes are corroded old steel or iron pipes. If it came from the water supply and/or the piping system and other water using appliances. Check the aerators on the sink faucets and inside the toilet tank. If any of those locations have the same problem, it may be the water supply or the water piping system. In those cases, other major problems exist, which will not resolve the washer problems.
Some of that "grit" may actually be coming from your washing detergents. Try running a cycle through with hot water only.
Then make sure the seals are clean. Try another load and see if the symptoms return.
Oct 03, 2009 | LG WM1814CW Front Load Washer
Can I Use Existing Venting from Old Water Heater?
The only thing is I think the vent pipe foe the tankless is smaller than 5".I think the one I install was a three inch.
Mar 17, 2009 | Rheem RTG74DVN Direct Vent Natural Gas...
Special water hose needed?
i dont know of of a"special hose". are we talking about water inlet (hot and cold) hoses??drain hose??? or a vent hose for dryer???
1. stainless steel non-bursting fill hoses are available in up to 6' lentgh's
2. drain hose can be extended if need be, i would make it as short of an extension as needed, and use a hose of atleast the existing diameter and make sure that it wont, bent or pinch off after putting into drain pipe
3. dryer venting should be a solid aluminum 4" pipe as shosrt as possible with least amount of elbows needed.
all available at a quaitly home improvemnet store/ hardware store
Oct 30, 2008 | LG WM-2277HW Front Load Washer
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Error H F
this code will set for two reasons if the washer doesent start filling after 30 seconds or fills to10.5 gallons in eight minutes and the pressure sensor hasnt triped so time it and post a reply to your message letting me know which condition exist make sure your drain hose isnt too deep in your drain pipe as this will siphon water out as it fills and mke the washer think the second condition exists consult your owners manual for proper drain hose instalation
Dec 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
