Question about Zenith C27V22 27" TV
Zenith 27" TV ( Regular, no Hdtv)
My Tv playes OK then the screen changes to pink & red. It will be this way for awhile, then change back to a normal screen. I did all the adjustments, but it still changes back and forth. I tightened all the cables, and even tried putting a wedge under it. It will be good for awhile, then change. Any ideas? Thanks
  • xman2 Mar 18, 2008
    Thanks for your help. Will try to get someone to look at it.
Do you have speaker system near by , check and remove if and look
Posted on Mar 22, 2008
  • 373 Answers
Likely to have a bad solder connection on the board on the CRT inside the tv
Posted on Mar 16, 2008
SOURCE:
Its a zenith 27in the sound is good but the picture only shows a line across the screen
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
May 04, 2011 | Zenith C27A24T 27" TV
Black screen
Not good. Make sure you have not blocked cooling to TV. It need s air flow. sounds like overheating
Mar 25, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
I just got an xbox 360 for christmas and I play it on my Apex PF 2725 tv. I have it connected to the first Video component with the red white and yellow cords (its set to TV and not HDTV) On all of my...
orite if you have a HDTV plug in all leads apart from yellow 1, but if its normal tv just insert the white, red, yellow. : ), i aint an expert yet
Jan 15, 2009 | Apex Digital PF2725 27" TV
Screen has green corner at first and may changeto pinks and green
It sounds like the De-gauss circuit isnt working. It demagnetizes the TV tube.
It's something only a tech can fix though.
Jan 02, 2009 | Zenith C27V36 27" TV
Junk TV & Poor service
zenith agreed today to replace mine.
Mar 12, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Red to pink screen after 5-10 minutes of play....
This is not the tube, it's most likely the colour controller and system function ic has gotten scrambled, taking this to a tech to re program should not cost more than about $150 AU
Feb 09, 2008 | RCA TruFlat 27F520T 27" TV
Zenith C27V22 27" TV loud humming noise
There is a coil in the set with a magnet glued to it, called the horizontal linearity coil. Sometimes the coil "sings", making a squeeling sound. I have seen this many times, and there really isnt anything actually electrically wrong with the set. To stop the squeeling the coil should be replaced.
Jun 19, 2007 | Zenith C27V22 27" TV
Speakers have died?
Probaby the stereo decoder IC went bad or a supply voltage to it is too low or noisy. If it has audio output jacks on the back of the TV, connect it to an external amplifier and see what that sounds like. If it is ok in stereo or mono mode then the amplifier in the TV is bad. This will prove that the stereo decoder is ok.
Feb 01, 2007 | Zenith C27A24T 27" TV
Black box on screen
On your remote should be a button called TV caption or text. Turn off the closed caption as someone hit it and turned it on by accident. If its not on your remote, then it is in the menu. Good Luck Ps Please dont forget to rate this thread.
Oct 25, 2006 | Zenith C27A24T 27" TV
Zenith C27V22 27" TV Logo
69 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
