Question about Nokia 5200 Cellular Phone
Will not power up
If I try to power up nothing happens. I have tried to update firmware but no joy Phone still appears to work as battery charger. Any ideas, please?
  • taprec Apr 01, 2008
    my nokia 5200 is fully charged but when I swotch it on , it goes on up until the nokia greeting then the display goes blank...
  • 85 Answers
Check or replacs ur on/off buttun
Posted on Mar 16, 2008
My mobile set dead how checking plase give me process
This has probably happened to everyone at some time: You press the POWER button on your iPhone - and nothing happens. Usually, this can be resolved easily. Either your battery has run down, or iOS has "crashed" and needs to be rebooted. On rare occasion the firmware has been corrupted, but let's save that for last. The following steps will usually get your phone working again in a few seconds:
  1. Unless you are absolutely certain that there is plenty of charge left on the battery, connect the phone to a wall charger for at least 15 minutes. If it was just a low battery the phone will come on by itself. If it doesn't go to step 2.
  2. Hold the HOME and POWER (aka SLEEP) at the same time. An Apple logo should appear in 10 - 20 seconds. Relase both buttons, wait about a minute, and your phone should be back to normal.
  3. Occasionally it may be necessary to toggle the Mute switch a couple of times before Step 2. No one is sure why, but sometimes it helps if just holding the 2 buttons doesn't work.
If absolutely nothing happens after step 3. either your phone is broken, your cable is defective, or your charger has failed. Try different chargers and cables to isolate the problem. Or take all of them to an Apple store for diagnosis (make a genius bar appointment before going).
If you get an error message, or you see a picture of a USB plug and iTunes, you will need to restore your phone with iTunes. This, fortunately, is a very rare occurrence.
Oct 11, 2014 | Cell Phones
My phone wont turn on
Is their any indication like the red light blinks only? Just do the basic steps first.
* You should try another battery to see if your old one is drain and need to replace a new one if it is working.
* Also try to check your charger,try to test another charger,might your charger is damage due to intermittent wires,improper keeping or rolling the wires so tight.
* You can also test a usb cable and plugging it to the computer,if the pc recognized the phone, either the two above hints need a replacement.
* also try to connect your phone to power supply or usb (connected on computer)without the battery for a minute the plug the battery again and check if the phone initialized.
* Otherwise,you need to update the firmware of your phone,might the software has been corrupted,to do this method,follow my TIP here on how to flash or update your phone firmware
CLICK ME
If you have some questions,please don't hesitate to reply.
Thank you for visiting FixYa....
Jul 17, 2011 | Blackberry Curve 8350i
Phone was working fine then battery went out of charge,when I got home I PLUGED IN MY CHARGER AS NORMAL BUT NOTHING I HAVE TRIED SEVERAL TIMES TO GET TO GHARGE BUT NOTHING.
Try these and tell me the result.
1. Try to charge from a different charger.
2. Use another battery and try to on the phone.
3. After plug on the charger press power on/off button for a while. If nothing happened on your mobile after use these 3 tips then visit Nokia service center for installing the operating system on your phone. If the OS is corrupt then the mobile going under dark. No movement, no signaling of charging nothing. Even you can't update it from internet right now. Because the phone memory is fully dead. Its happened with all mobiles if the OS corrupt. Its was happened also in my Nokia N73.
Thanks &waiting for your reply.
Feb 04, 2010 | Nokia N95 Cellular Phone
My nokiA3110C NOT STARTED AND WHEN STARTED ONLY SEE LOGO BLINCK 3 TIMES AND THEN SWITCHED OFF BUT NOT CONNECTED PC WITH USB
my 3110c is not powering on, when i press the power button, power supply machine shows some ampere load but phone is not powering on. please give me solution.
Dec 11, 2009 | Nokia 3110 Cellular Phone
Nokia 5800 Lights on but no screen
change your battery....battery problem......
Jul 03, 2009 | Nokia 5800 XpressMusic Smartphone
Hi my sony ericsson k800i stopped working . when i try to power it on. the infra red light flashes three times and nothing else happens can you help?
The first thing to do is try a different, fully charged, battery - one of things that can cause that flashing LED is if the battery is really flat. If you don't have access to a spare battery, then try plugging in the charger and see if that LED comes on solid - then leave it for an hour or so.
If that doesn't work, the next thing to do is download the Sony Ericsson Update Service client from the SE website and try and do a firmware upgrade - if it says you already have the latest firmware, just select "Update anyway" - this will delete all the content in the phone (but not the memory card), however.
If you can't get SEUS to connect when you plug in the phone holding the "C" key, then try plugging in while holding down "2" and "5" and see if that works.
Jun 11, 2009 | Sony Ericsson K800i Cellular Phone
Samsung ace won't turn on
Usually that happens when the firmware update failed. Try to connect your phone again to your PC then try to update again.
May 27, 2009 | Samsung Ace SPH-I325 Car Charger
Just stopped working, cannot charge, red light only
It could need a new battery. It doesn't sound like it's holding a charge anymore.
Apr 14, 2009 | RIM BlackBerry 7290
Does not charge properly
If battery is blinking but not moving forward then replace ur battery.regarding the stick plz contact hardware vendor.
Oct 15, 2007 | Sony Ericsson K700
Won't power on
Battery is too low for player to charge. There is a firmware fix for this at www.p4c.philips.com
Fix cannot be applied until player is working again.
If you know someone who has the same player, put their battery in your unit to power up and apply firmware update to fix problem. Then swap batteries back again
Another way to get the player working is to remove the side panel to disconnect battery. Plug in the mains charger and reconnect the battery. You may need to do this several times before the player springs into life.
If this doesn't work try disconnecting the charger and battery alternately and wait 5 secs between attempts.
Dec 13, 2006 | Philips HDD070 MP3 Player
Nokia 5200 Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
