I have Kingston 2GB USB Flash Drive, it was working fine, but now when i plug into my computer is not ever deteded,and I have my importance information on. how could I make it work again, please help? hi, my DTI/GB kingston pen driver r not working properlly, when i connect it in system it prompt as unknown device, or msg show windows XP does not recognies it please help me how could i solved my promblem
check driver of this drive in device manager.and click on(scan for hardware change) in action menu.If still not responding then do this
right click on my computer
click on properties
click on hardware
click on device manager
click on universal serial bus
click on(+)
then right click on this pan drive driver(if taken) other wise on yellow ? mark
click on update driver
select second option in window(advanced)
then click on( search removable.......)
then insert driver cd in cd rom
And click on Next option
If you have done this then do this
if it is not work then do above procss and select third option(Don't search.I will...............)
And click Next option
click Next option in next window.Thats it
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
yes, it need its driver in order to works, usually the window will recongize it but if you have the disk that came with it, your driver should be on it.
I own a Palm TX and am thinking of getting a cellphone with a PDA - what are your thoughts on this? ...
(More)
I own a Palm TX and am thinking of getting a cellphone with a PDA - what are your thoughts on this? I am worried if the phone quits I lose the use of my PDA and all my info. Help
My g1 has had a little water damage that has only affected the speakerphone. It will either produce...
(More)
My g1 has had a little water damage that has only affected the speakerphone. It will either produce medium volume,full volume,or no volume given the day...since it sometimes will work perfectly I don't believe the speaker is completely ruined but I just need it to work all the time...
