Question about Refrigerators
Compressor problems how long does the Compressor on the frigidaire r5303b stay off for...i had the thermostat set to 5 and when the Compressor switched off it never came back on again after an hour the fridge wasnt cold so i had to switch it to 7 so it would start again
  • Anonymous Dec 13, 2008
    It was a defrost problem and when I switched it off and tried to put it back on it does not work there is no light
    President:
  • 1,314 Answers
It varies with door oppenings stuff like that sounds like you may have a faulty cold control the cold control has two settings a cut on setting and a cut out setting you cut in setting may be bad id replace the cold control
Posted on Mar 15, 2008
My refrigerator freezer wont stay running longer than 4-6 hours. Stops calling for compressor to kick on. any ideas?
i suspect a defrost timer issue but u may want to check the temperature control switch and ur thermistors as well
Apr 17, 2015 | Frigidaire Refrigerators
Frigidaire freezer ffu14f5hwg red light on
It isn't reaching temperature. The red light comes on at -12c Check the condenser is clean, thermostat set ok and compressor humming nicely
May 22, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire FRA256ST2 compressor stays on for about 3 mins then goes off for about 3 minutes, we have the temp set for 76 and it says 80 on the thermostat
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 02, 2011 | Frigidaire FRA256ST2 WallWindow Air...
Fridgde shut down. freezer droppped to 48 degrees and fridge at 68!!!!is it the compressor? Its only a year old!
If it's only a year old then the compressor/sealed system is under warranty. You should have a 5 year warranty. Go to www.frigidaire.com and request service.
Sep 26, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condensor
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
Thank you for using FixYa
Jan 17, 2010 | Refrigerators
Will not freze only 5 years old
hi friend,
3 possible reasons ...1 thermostat is bad or is set to high....2 bad compressor start relay or bad compressor...3 freon leaked out...when you plugged it back in did compressor run...if no check thermostat....check relay..its mounted on side of compressor...if yes then low freon...
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Frigidaire Freezers
Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Jun 16, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Thermostat
air conditioner wont reset
Feb 19, 2008 | Heating & Cooling
Refrigerators Logo
255 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
