Question about Panasonic Lumix DMC-FZ20 Digital Camera
Tiff problems Tiff files are color distorted. Also frame is "wrapped". It appears tha the file is truncated with a portion left over on the left side. Should have been part of the main frame.
  • 1 more comment
  • Anonymous May 28, 2008
    The color has been reversed on my TIFF files- a bright canary yellow comes in as turquoise blue. Very trippy. The frame is also shifted, with a small portion off the right side appearing on the left, as if it were pushed and came back around. No idea what to do.
  • Anonymous Jun 09, 2008
    I do have exactly same problem and do not use Kingston memory.My card ATP Pro Max is fine with jpeg but not with tiff
  • Grazhoppa Nov 02, 2008
    I couldn't find anything on this when I searched, so I posted a new topic... anyway...
    I get this problem with SanDisk cards of 1GB+, though I can't say I've tried any smaller than that.
Turns out it was my SanDisk 2 GB memory card- tried a 512 MB card and it worked like a charm
Posted on May 28, 2008
I still haven't solved the problem completely, but I've narrowed it down to Kingston 2G chips. I have 3 other manufacture brands that do not exhibit the problem. I've contacted Kingston this weekend but need to talk to their second level support team on Monday morning. Will upday you when I get an answer from them.
Posted on Mar 17, 2008
SOURCE:
Besides Gif images, what other types have transparent background?
File formats that support transparency include GIF, PNG, BMP and TIFF, through either a transparent color or an alpha channel.
Source: http://en.wikipedia.org/wiki/Transparency_(graphic)
May 20, 2014 | Adobe Photoshop Elements 7
How do you set the copier to scan as a pdf file all the time?
08-218
Default setting of filing for-mat when storing files (at color/ACS modes)
SYS 0: TIFF (Multi)
1: PDF (Multi) 2: JPG
3: TIFF (Single)
4: PDF (Single)
08-219
Default setting of filing for-mat when storing files (at black mode)
SYS 0: TIFF (Multi)
3: TIFF (Single)
4: PDF (Single)
5: XPS (Multi)
6: XPS (Single)
Jun 27, 2012 | Toshiba E-studio 281c Copier
Cannot view color Tiff images using windows picture and fax viewer. Windows XP
TIFF files come in various formats. Check if your file is only TIFF and NOT TIFFJPG.
S. Mohan
Apr 28, 2011 | Canon DR6050C Scanner Color Duplex Scanner
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
SCANS PAGE IN TOO LARGE
Uncompressed TIFF files are large in size. If you want Black & white and also small size save in TIFF G4 format. JPG files are small, but only color and grey files can be stored in JPG format.
S. Mohan
Oct 01, 2009 | Fujitsu fi-5120C
Corrupted tiff files from scanner on sharp AC-1642CS
Clean the scanner glass if no change , format the computer and install the softwares again but firs you can test with another computer.
Mar 19, 2009 | Sharp AL-1642CS Copier
Download mp3 music
Power ON the frame.
Now you can play.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Audio Players & Recorders
Problems taking TIFF photos
I have seen similar problem on one of the SD card. Tried another SD card and it works fine with TIFF. I think it is related the the SD card compatibility.
Jun 22, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
Panasonic Lumix DMC-FZ20 Digital Camera Logo
156 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
