Question about Western Digital Essential NetCenter (WDXE2500JBN)
Light around on/off-button flashing / no access
I have also a problem:
I have a 500 GB Netcenter, linked to a router
(Syslink). This morning, as I switches the harddisk
on, the light around the on/off button flashes from
blue to red and I have no access to the programs
and resources anymore (I think I have downloaded
500 GB full onto it and that is why the harddisk
won't work anymore...I did burn away data regullary
but could not do that lately).
Can anyone tell me:
Did you have the same problem and how did you
solve it? Would push the reset-button on the
backsite of the harddisk solve it or would I loose
all the data by doing that?
So I can not access the data anymore, no matter
from what computer I try....
Thank you very much indeed.
  • floydco Apr 14, 2008
    I have the same problem, the drive spins up and the relays click three times and the drive shuts down. The reset has no effect, only starts the same procedure all over again.
  • megacrash Oct 25, 2008
    Same problem here.
    Mine started when trying to copy things from it , to recover my wife's crashed PC. The netcenter started locking up.
    Then one last time, that was it, it never came back.
    Seems these drives have a problem. They use a form of Linux and write "super" blocks. Which is suppose to be a safe thing. Until just one to many things are attempted at the same time, and it looses track of it and it's file table. Later versions the os have that fixed.
    That's the way it's been explained to me.
    I'm pretty darn PC savvy, my daughter's bf is even more. He took on the challenge for me and looked into it. He works for a consulting IT company. He used some Linux based pro tools to do file recovery on the drive after removing it from the netcenter case.
    So if you want to try and do a recovery, get a machine up and running on one of the Linux releases, get some recovery tools for it, and give it a whirl.
    What ever you do, don't attempt to reconfigure the hd , or write to it. Just nothing but read. Otherwise you can forget about trying a recovery project.
    With my data off the disk, well about 90% of it. I put the drive back into the netcenter, and while it shows all the space available, when I created a new volume in the netcenter manager, it says there isn't enough space.
    I have an email into WD asking what needs to be done to prepare a drive for the netcenter after such a crash.
    Scholar:
  • 98 Answers
Draft beer systems may seem somewhat complicated at first glance. But once you tackle the basics, you'll see that they're actually quite easy to understand. From keg pressure settings and standard definitions, to keg dimensions and pouring techniques, we're here to tell it all. Quench your thirst for knowledge and become a smarter, more educated draft beer connoisseur.
Posted on Mar 17, 2017
Link failed and flashing light
      it sounds like you have locked the Router into Firmware Flash mode by incorrectly performing the reset steps which are :
      To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a
      paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
      Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
      If however, one presses and holds the Reset button while it's off, then turns it ON, then it will start the flash process and flash the power light orange.
      To recover, you will need to re-flash the Router.
      Here is the D-link support page to find your firmware, you will need to find the correct "version" of the 615 you have and download that file, (you will need to un-zip it,) then follow these steps :
        1. Disconnect the power cable from the router.
        2. Open a web browser and type in the URL http://192.168.0.1/ but DO NOT PRESS [enter] or the [GO] button yet.
        3. Press and HOLD the [reset] button on the router and connect the power cable. Continue to hold the [reset] button for about 10 seconds, then release.
        4. Now click inside the address bar of the browser and press [enter] or the [GO]. The "Emergency Room" Updating Firmware screen should display.
        5. Browse to and upload the DIR615_v4.11_B02.bin image file.
        6. When you see the message "IMAGE UPLOAD SUCCESS", the flash will begin to be erased and re-written.
        7. Use your browser to again connect to the router at http://192.168.0.1/ or press [F5] and refresh the page.
        The Dlink setup screen should load. If not, you did something wrong. Go back and try again.
Aug 31, 2012 | D-Link DIR-615 Wireless Router
I have a dlink dir 600 router. i have reset it and still can't connect to the router settings. i have tried 192.168.0.1,192.168.2.1 etc but the best i can get is a 500 internal error or a 404 erro
Press and hold the RESET button at the back of the router with the power ON until the LEDs flash at the time the release the RESET button. (firmware version was 3.00, and upgraded to 3.05) Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Aug 30, 2012 | D-Link DIR-600 Router
My families WD western digital net centre has suddenly got a blue and orange flashing light and none of us can access it to get our documents, photos and music. is everything lost forever? how do we fix...
Hardware damage - yes , most likely all the data is lost.
You might have a slim chance of recovering something if you take the actual hard disk out of the WD casing and you connect it directly inside a desktop, if it's still working at a basic level it should appear in My Computer.
May 16, 2011 | Western Digital NetCenter WDXE5000KSN 500...
My DI-524 router was working perfectly fine until one day i lost connectivity and the power and 4 light were flashing. It is now two days later and is still the same, I've tried solutions around the...
Have you tried RESETTING the D-Link back to the default settings?
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 21, 2011 | D-Link AirPlus DI-524 Wireless Router
Forgot wireless access code how do you change it ?
Look at the back of the router for a Pin Hole button, it is the "reset" button.
Hold the button in for 10 seconds and release. Now you can log in using the default username/password.
If you had any custom settings, they are gone now, you will have to redo them.
If you do not know the default password, use the following link to find it.
http://www.phenoelit-us.org/dpl/dpl.html
Jul 10, 2010 | Belkin (F5D7230-4) Router (587009)
How can I make a password for my D-Link 520T Router?
If you wanna go wireless and your router is not wireless, you can simply buy a wireless access point. Connect it to your router and it will give you wireless service, hence your laptop can connect wirelessly now. You can just buy a D-link wireless access point.
Nov 16, 2008 | D-Link DSL 500 (DSL-500) Router
Access Denied errors
Same problem for my on my brand new drive.
I found a solution on the web that points to reformatting the drive as a fix:
http://mybookworld.wikidot.com/forum/t-50207/cannot-delete-files-read-only-dev-md4-on-mybook-we-i-1tb
I can't be bothered and am going to try and sell it.
Apr 25, 2008 | Western Digital 500GB My Book World...
DLINK ROUTER DI-624M
Press the reset button on the back of the router and hold for 10-15 seconds, this resets router to factory defaults. Access the router using the IP address of the router http://192.168.1.1 access the router setup and create your PPPOE internet connection provided by your ISP using your username and password connect to the router via the computer. BPCS
Dec 29, 2007 | D-Link DI-624M Router (DI624MRE)
Western digital netcenter drive
I had this same problem.  The solution is to unplug it from your UPS and plug it directly into the power outlet.  I know this sounds crazy but afte 1.5 hours on the phone with WD tech support I finally got to a top level tech and he said this is a common problem.  They just don't work consistantly when plugged into a UPS.
Apr 10, 2007 | Western Digital Essential NetCenter...
Computers & Internet Logo
977 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
