New samsung 37"lcd the picture leaves a ghost when people move on screen i have tried to fine tune but nothing what can i do as im a bit thick when it comes to these things.
  • 807 Answers
TV has a slow response time. Only cure is to buy a faster one.
Look for the response time of the TV in the description.
The lower the better. 12 mS is slow 4 mS is faster and smoother.
Posted on Mar 15, 2008
Sony Bravia 46'' picture has a slight green tint and adjusting the Hue does nothing.
hello!
that could be the t-con to main board cable's problem. first, try to tighten grounding screws.those, which connecting grounding latches of the cable.
You need to open your set. This cable is a thick shielded one with two 30 or so pins plugs. They are NOT interchangeable. In case you try to swap cable's ends. Try to move latches by hand without unplugging connectors, while TV is running. Very gently! If those moving a bit, you may see "greenge" vanishing. Tighten those screws with "phillipls" screwdriver by hand. if there is no difference, you may need to replace that cable. I'm talking about "greenish" ghosts on the picture, intermittent. If I'm wrong, it might be the main board's issue, but always start with small. Main boards are not interchangeable, factory replacement only! Cables-are.
Good luck,
Alex.
Nov 26, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
No picutre just black-loud pop when I turned it on
You may have blown parts, look inside and inspect the power supply module and the back light inverter board, I will leave the TV unplugged.
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Jun 25, 2010 | Samsung LE37B550A5 37 in. HD-Ready LCD TV
Im having the same problem with my samsung
probably will have to call 1-800-samsung to find your nearest repair and parts center.
Nov 16, 2009 | Samsung LN37B530 37 in. LCD TV
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Pixelated lcd tv picture
it indicates that the problem is aspect ratio or pixel settings for thescreen
bring up the on screen menu and adjust the pixel setting to fit the screen or the apsect ratio to fit the screen
read the operators manual to see how the adjustments are made
May 19, 2017 | Sylvania LC370SL8 37 in. LCD Television
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Dec 30, 2007 | Televison & Video
Green shadowing on Samsung LN-S3251D
sounds like you need a service call if it's in warranty, if not in warranty, you may need to have the logic main board replaced
Jan 30, 2007 | Samsung LN-S3251D 32 in. LCD HDTV
Computers & Internet Logo
47 people viewed this question
Alun Cox
David Payne
David Payne
