faq.fujifilm.com > Support > Q&A > Digital Cameras
Aug 13, 2012 - If no sound is heard while playing back a high-definition movie "HD" or a ... and Z series digital cameras · Should I remove the battery from the digital camera after use? ... If you need answers, please use the contact us form.
Olympus CorporationThe camera may also have options to shoot videos with and without sound and at ...When shooting videos with sound, the DIGITAL ZOOM must be set to ON so ...
AV VIDEO CABLEYellow- Video
Red- Right sound R
White- Left Sound L
Component Cables
RED ORANGE- video
BLUE- video
GREEN-video
RED- audio R
WHITE-audio L
HDMI
provides both video and audio all in one.
Optical out Audio
Audio format to surround sound. Better sound quakl
Hope this helps
To clarify, your TV is working correctly, since you get sound and video from all devices - Only your PS3 has no sound or video?
If your PS3 was previously used with regular AV cables (Red/White/Yellow) then you most likely need to do a PS3 video reset t output video over HDMI.
With the PS3 OFF, press and continue holding the power button until it turns on, beeps twice, and then turns back off. Do not release the power button during this process.
You may have to try the video reset a few times if it doesn't work right away.
After video reset, you should get sound and video over HDMI.
S-Video does not have sound, you will need to run separate audio cables to your sound cards input ports. S-Video is only for the video signal (Chroma and Luminance), there is no provision for sound.
Did you hit the "input" or "video source" button by mistake on the remote or TV? That would change the input from the one the cable/video source uses. You're getting sound, so it's working......sounds as if the input was maybe changed. I'd hit the input/video source button a few times to go through all the available inputs and see if you get video back.
There is no sound carrier on an S video connection. It's Video only. use the AV left and right cables for the sound. It is normal not to monitor audio when capturing.
