1995 GMC Sierra C1500 Logo
Posted on Apr 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need diagram of installation of power steering bracket on a 1995 gmc 1500 with a 5.0
ZJ Limited
Level 3:
  • GMC Master 17,989 Answers
  • Posted on Apr 01, 2010
ZJ Limited
GMC Master
Level 3:
Answers
17989
Questions
0
Helped
14456922
Points
60858
I suggest visit autozone.com (free register) and check all the information about this subject in there.
Good luck.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
470
Points
Need a diagram for a 1985 gmc 1500 steering wheel assembly need instructions
Need a diagram to know which brackets are needed to replace the front bumper on a 2006 GMC Sierra 1500 Crew Cab.
Hi, if you tpe in your make and odel, followed by your question, the name of the bracket size will become clear to you
I need a digram for a 97 gmc 1500 without hydroboost power steering pump
what kind of diagram and engine.. i can help you just would need the last 8 of your vin number and more specific info on what kind of diagram
1helpful
I need an Illustrated Parts Break down for a 1989 GMC Sierra 1500. 350 w/ PS/PB loaded. Steering column Removal Repair or Replace
Hi.
Below you get all the parts breakdown for GMC Sierra 1500, including steering column assembly:
1500 SIERRA
Here diagrams for all 1989 GMC trucks.
If you need to take apart the steering column you will also need wiring. below the color codes and wiring tips:
GMC SIERRA 1988-2005 VEHICLE WIRING
Regards.
Ginko
How do I get my power steering pump out of 2002 yukon
Hello walker_227,
Removal Procedure:
SPECIAL TOOLS: You will need a power steering pulley remover and installer tool, DO NOT USE A HAMMER.
1. Remove the power steering pulley.
2. Raise the vehicle.
3. Remove the oil pan skid plate from the vehicle, if equipped.
4. Place a drain pan under the vehicle.
5. Remove the power steering pressure hose from the power steering pump from underneath the vehicle.
6. Lower the vehicle.
7. Remove the return hose from the power steering gearbox and the power steering pump.
8. Remove the bolt retaining the rear bracket to the engine.(See picture below)
9. Remove the bolts from the front of the pump.(See picture below)
10. Remove the pump from the vehicle.
11. Remove the bracket from the rear of the pump
Installation Procedure:
1. Reverse above procedure
2.Fill and bleed the power steering system.
Serptine belt diagram
Belt Installation, Aerostar 4.0L Engine
Item Part Number Description 1 8620 Drive Belt 2 N606068 Bolt 3 10300 Generator 4 10153 Generator Mounting Bracket 5 8509 Water Pump Pulley 6 6B209 Drive Belt Tensioner 7 N800199 Screw 8 8678 Belt Idler Pulley 9 N802096 Screw 10 19703 A/C Compressor 11 2882 A/C Compressor Mounting Bracket 12 3C718 Brace 13 N806020 Bolt 14 3A674 Power Steering Pump 15 3A733 Power Steering Pump Pulley 16 N800199 Screw 17 N606572 Bolt 18 N620481 Nut 19 8501 Water Pump 20 6312 Crankshaft Pulley A - Belt Tension Check (See Specifications) B - Tighten to 40-55 Nm
(30-41 Lb-Ft) C - Tighten to 24-30 Nm
(18-23 Lb-Ft) D - Tighten to 21-29 Nm
(15-21 Lb-Ft) E - Tighten to 40-50 Nm
(30-37 Lb-Ft)
Belt Installation, Ranger and Explorer 4.0L Engine
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator 3 8678 Belt Idler Pulley 4 19703 A/C Compressor 5 3A733 Power Steering Pump Pulley 6 8501 Water Pump 7 6312 Crankshaft Pulley 8 6B209 Drive Belt Tensioner 9 N806020 Bolt 10 2882 A/C Compressor Mounting Bracket 11 3A674 Power Steering Pump 12 N606572-S2 Bolt 13 N800199-S8M Bolt 14 N620481-S2 Nut 15 3C718 Brace 16 N606068 Bolt 17 10153 Generator Mounting Bracket 18 8509 Water Pump Pulley 19 N605805-S2 Bolt A - Belt Tension Check (See Specifications) B - Tighten to 21-29 Nm
(15-21 Lb-Ft) C - Tighten to 40-55 Nm
(30-41 Lb-Ft)
Belt Installation, Ranger 2.3L Engine
Item Part Number Description 1 8678 Belt Idler Pulley 2 10300 Generator 3 8509 Water Pump Pulley 4 3A733 Power Steering Pump Pulley 5 2E884 A/C Clutch Pulley 6 6312 Crankshaft Pulley
Belt Installation, Aerostar 3.0L Engine
Item Part Number Description 1 10300 Generator 2 3F671 Belt Idler Pulley 3 3A733 Power Steering Pump Pulley 4 6B209 Drive Belt Tensioner 5 6312 Crankshaft Pulley 6 8509 Water Pump Pulley 7 19703 A/C Compressor 2010&c18=modelyear&c35=wsm%2cdrive%20belt%20replacement%2cssk%2c03-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
What type of power steering fluid in 1995 gmc jimmy
There is no special power steering fluid needed for a GMC Jimmy. Simply go to the auto parts store and ask for power steering fluid.
1helpful
Removal of power steering pump on 1998 GMC Sierra 1500
you need a power steering pump puller the rest is simple any trouble let me know
Need the belt diagram for the water pump belt for a 95 Auroa
42161874BELT, REPLACE
  1. Release belt tension and remove belt from power steering and alternator pulleys. Twist belt to get between tensioner and front cover and between power steering pulley and engine mount bracket.
  2. Raise and support vehicle.
  3. Turn wheel to the extreme right and remove right side splash shield.
  4. Remove belt from crankshaft and A/C compressor pulleys. Twist belt to get between idler pulley and engine mount bracket.
  5. Lower vehicle.
  6. Twisting new belt to get past the front cover, install belt around power steering pump pulley, Fig. 15. Allow belt to hang free.
  7. Twist belt to get between tensioner and front cover, wrap belt around alternator.
  8. Remove belt from power steering pulley and set aside.
  9. Raise and support vehicle, then twist belt to get between tensioner and front cover, wrap belt around crankshaft and A/C compressor pulleys.
  10. Install right side splash shield and lower vehicle.
  11. Position belt around power steering pulley and release tensioner.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
