Hitachi Microdrive 4GB won't write or format
I have a Hitachi 4gb microdrive which has suddenly stopped being recognised by anything. I have tried a mac, a PC, an Ipaq, a digital camera. None of them will see it or allow me to format it. When you first plug it in it makes a whirring noise that repeats with a very slight pause after which it stops making any noise at all.
Is there any way that I can fix this problem?
  • 88 Answers
I'm afraid that sound like a dead drive.
Posted on Mar 15, 2008
SOURCE:
What format do you use to reformat a 4GB microdrive?
I've seen quite a few posts in here about using 4GB microdrives in the S2 camera which many have had formatting problems with resulting in an initialization error. This happens because the microdrive is most likely pre-formatted as FAT32 vs FAT16 or just FAT. The S2 will not recognize FAT32.
Here's a way to format it that I've found works every time when running Windows XP Pro service pack 2 as your operating system.
A few things to mention first.
As you know a microdrive tends to use a bit more battery power than flash type CF's. Therefore I highly recommend connecting the AC power supply to your camera before attempting any of this! Your batteries may not last long enough for the format process to complete as it does take a while for 4GB. If they should go dead while formatting I don't know what will happen. Suffice to say whatever does happen probably would not be good.
Ok, here we go.
Open "my computer" or whatever you have it called on your machine so that you can see all your drives. Install the 4GB CF Microdrive into your S2. Connect your firewire and the AC adaptor to your camera and then turn it on. The function screen on your S2 should say "I394 DOWNLOADING" .
Now look a the drives you have on your computer, a new one should appear. Write this down as you will need it later. On my machine it shows up at "Removeable Disk (K:)"
If you turn your camera off it will no longer show up so you can double check this if you wish simply by turnign your camera on and off. Write this drive letter down, you will need it later in these directions.
Ok, once you're all hooked up, camera is turned on, and know what drive the camera is showing up as go to "start" on your toolbar. Select he following: start / programs / accessories / command prompt
When the command prompt window appears type cd\ and hit the enter key.
You should be seeing the prompt C:\> at this point.
Now type cd windows\system32 and press enter.
The prompt should now be C:\WINDOWS\system32>
Here's where you MUST be careful!!!!! I can not stess this enough!
You're going to be using the dos format command. If you tell it to format the incorrect drive YOU WILL have a serious problem on your hands!!!
Once a format process has started whatever drive you have selected will be trashed for all practial purposes. Needless to say if you format your boot drive your machine (typically drive C:\) it will be rendered completely usless and a total reinstall of the OS will be required. make no mistake, ALL DATA WILL BE LOST!!!
ok, continuing on...
Remember what drive your camera was?
Mine was K: - substiture the drive letter that yours is in place of the K below.
Type format K: and hit the enter key.
You will be prompted with the folllwing message "Insert new disk for drive K: and press enter"
press enter.
The next prompt you will see is "The type of the file system is FAT verifying 3905M" and then followed by "??% complete"
Once it has formatted 100% of the drive you will see this prompt. "WARNING! the cluster size for this volume, 64K bytes, may cause application compatibility problems particularly with setup applications. The volume must be lass than 2048MB in size to change this if the default cluster is used. Proceed with format using 64K cluster Y/N?"
Type Y for yes and hit enter.
The next prompt will get is "Initializing the file allocation table "
"Volume label ?"
Here you can give your drive a name, if you do not wish one press enter, if you want one, type it in and then press enter.
I used MDR4GB so that when I hook my camera up I can easily tell what drive I have in it at that point.
Anway, after you do or do not give it a label and press enter you
you should be prompted with this;
"Format complete.
4,094,885,888 bytes total disk space.
4,094,885,888 bytes total available on disk.
65,536 bytes in each allocation unit.
65,483 allocation units available on disk.
16 bytes in each FAT entry.
Volume serial number is whatever your computer assigns to it
c:\WINDOWS\system32> "
Type the word exit and hit enter to close the command prompt window.
Your microdrive is now formatted with a capacity of 4GB for use in your S2. The only issue you will have is that the counter will not function. Sequencial file numbering will not be effected. I do not know of any way around this but the added file capacity is well worth the inconvience of not knowing how many images remain before the card is full. If you have a typical setting that you're used to you can get a feel for how many images you have left in time. Some say, why bother? I say why not. I just picked up this Hitachi 4GB drive from circuit city for $70 after rebates. That's darn cheap memory folks!!!! I can live with no counter for now.
If anyone knows how to get the counter back using a 4GB microdrive I would certainly be interested in how to do it. To bad Fuji does not offer firmware upgrades to solve this issue with the S2.
Oh yea, one other thing. DO NOT attempt to format this drive in your camera. It will not work and you will get an error of some sort. Just delete the images after you have downloaded to your computer and then go back out and snap away.
Have fun shooting, hope you have found this information helpful.
Oct 22, 2013 | JVC Everio GZ-MC200 Camcorder
I have a hitachi 4gb microdrive with 1 corrupted file. There is over 300 pictures and I can't download them because it gets to that one corrupt file and stops. How do I resolve this. Thanks for the help.
You could try using a card reader instead of the camera to download to a folder you create on your desktop. Once there, you can delete the corrupted file.
Aug 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My Hitachi Microdrive 4gb hard drive seems corrupt, but my computer still shows photos as jpg files (about 1000kb) and jrg files(30000kb, impossible). When I try to open them, the computer shows "no file"...
H there this mean a file is corrupt and you need to repair the damage file,you can do this by using a recovery disk for the computer if you have one.If you don't do not have a recovery disk for the computer you can use the operating system disk to repair it,please follow these steps:insert the operating system disk into the drive,restart the computer, press F12 and choose boot from CD save and exit.As the computer loading it will ask you to press any key to boot from CD, press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, this should solve the problem. But should backup your files before doing this even though no file will be lost but its better to backup just in case something goes wrong.
Jun 16, 2010 | Hitachi Microdrive (HMS360404D5CF00) 4 GB...
My NIKON D70 has trouble with flash cards larger than 2 G.
The D70 has known issues with certain cards / capacities. Nikon has identified the cards and capacities that are guaranteed to work with the D70 specifically, on their page dedicated to this info linked below:
http://support.nikontech.com/app/answers/detail/a_id/9601
It seems that only Lexar and Microdrive cards that are 4Gb are supported (some with significant limitations) and no card greater than 4Gb is supported at all, regardless of manufacturer.
Oct 10, 2009 | Nikon D70s Digital Camera
I have a hitachi 4gb harddrive that is corrupted and my card readers or camera wont recognize. How can I retrieve the data on the card?
You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 15, 2009 | Hitachi Microdrive (HMS360404D5CF00) 4 GB...
My lifedrive when plugged in comes up with the logo (palmone) however the screen will not change. Ive tried a soft reset and a hardreset does anyone have any suggestions. I have used this very little....
Unfortunetly that is typical of the internal microdrive having died on you. If the hard reset doesn nothing then that is most likely your problem.
You can replace the microdrive but if you want to improve your LD you can get it changed to use a compact flash disk such as a SanDisk 4gb card. It will run much faster and for longer. This is a simple thing to replace either but given the choice I'd go with the CF. There are several place that will repair your LD for you if you don't want to fix it yourself. You should end up spendingunder $100
Jul 07, 2009 | Palm LifeDrive Handheld
My 4gb Hitachi Microdrive (for my Nikon camera) stopped working.. No noise, no high-pitched whine, just would not be accessed. I have had a demo version of "Photorescue" running on it for about...
No Solution for me or my Microdrive. I tossed $20.00 away with no joy. The Technician was pleasant, and stepped through the things I had done. No fixYa for me. And yet, you want me to invest in the Premium Assistance plan?
MwS
[email protected]
Nov 24, 2008 | Hitachi Computers & Internet
Windows can't see images from my Hitachi Microdrive
In the first instance you should never format a media card/drive for a camera in a computer Windows does not know about the file type cameras need. Now getting your pictures back www.konvar.com - has PC Inspector Download and install this and run it through the card -preferably in a card reader, rather than still in the camera.
Aug 20, 2007 | Olympus EVOLT E-500 Digital Camera
Open Questions:
Malwarebytes CUsToMeR Service nUMber 1[\855/536*5666] USA O#+* Malwarebytes Antivirus CuSTomEr Service Number @+1855 536 5666 tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 17, 2019 | Carrier Computers & Internet
Malwarebytes Antivirus SUpPoRt nUMber 1[+*855*536*5666] UsA O*# Malwarebytes Antivirus Support Number @+1855 536 5666 tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Computers & Internet Logo
67 people viewed this question
Ekse
Alun Cox
