Unlockcode required i have a problem unlocking my nokia 3110 (black) my imei no.351939039909704.could you please help me unlock it with a master unlockcde?.
Depending on what you have for diagnostic knowledge and tools. You may want to send it in for diagnostics and repair. I can tell you that your vehicle's BCM (Body Control Module) controls these circuits. If it was a t my shop. I would first look for any fault codes. Then through the scan tool, manually command the doors to lock and unlock. Depending on what I find, take a closer look at the master control switch. This is in the drivers door and opens/closes windows and locks/unlocks doors. I'm forwarding you a couple wiring schematics just in case. I don't want to slow you down. FYI under the hood, inside the power distribution box. There is a relay for the tailgate lock/unlock. Any questions please feel free to write back. Good Luck.
A passkey is a single key designed to unlock a series of locks that individually require different keys to unlock them.
For example each hotel guest would have a key that would open only his own room and no others while the chambermaid would be issued with a single passkey that would open every room she has the right to access; perhaps a different passkey for each floor.
The manager and security guy would have a master key which would open every door on every floor.
? 0:51
https://www.youtube.com/watch?v=R9tQmL6YFcw
Jul 23, 2009 - Uploaded by rsweeting1
this show correct imei the correct code was entered and only say ... I am not sure What works I use this video and reset the code security in ...
? 3:48
https://www.youtube.com/watch?v=3XSq1UGYuk0
Jun 8, 2010 - Uploaded by MrJayacel
ezNK Clip (Easy Nokia Clip) adalah alat resetting code pengaman handphone Nokia DCT4+ bersifat ...
If you forget the phone security password then try default code like 0000 or 1234 to reset it .If it doesn't reset your mobile then visit Unlock Free com here they provide master reset code for your Nokia 1100 phone at free of cost. using this code you can reset your mobile and again set a new password.
You cannot unlock this phone at free of cost.But you can get the unlock code for your Nokia 6151 phone at low cost from Mobile-Unlocker.com here you need to specify your country, Network name to which
it is locked, IMEI number of your phone. Then they deliver unlock code to you
through mail with unlocking instructions. Using this you can unlock your phone
from Network lock easily.
Well there are only two reasons that you would post this same question over and over again asking for a free "unlock code" for your Blackberry. Either you are not smart enough to contact your phone service provider (who would be very well equipped to help you).
OR
The Blackberry does not belong to you and therefore you cannot contact the phone service provider without getting busted out.
Either way, my answer is the same... NO! I do not contact FixYa users via Email.
(If you read the user agreement you will find that this is against the rules)
Hey, pin unlocking process is concerned with your service provider and not with your phone. call costomer care and tell your sim card no.ask for PUK code(pin unlock code). this code will unlock the phone.
THE key code is what you need or a dealer should be able to give you a MASTER-KEY with the vin# and key code is on a little black tab in the owners manul package i hope this helps
