Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Promise SATA378(tm) IDE Controller
My Promise SATA378(tm) IDE Controller has a yellow exclaimation (!) next to it in the device manager list,The Device Status says "This device cannot start. (Code 10). and in the driver details it says 'not digitally signed, I've tried updating the driver but it says it can't do it, not sure what to do, don't really understand it all or what it means and after googling, I'm even more twisted than before, you assistance would be vey much appreciated,
kind regards Mitch
mitchstar8@yahoo.com.au
  • 655 Answers
You have to install the SATA driver from your Chipset. So find out your Chipset Model and go to the manufacturers site from there you can get it.
Download the driver and uninstall your old one after making re-boot install your new one.
For example I have Intel(R) ICH8 Family board and got my driver at this link (click here).
I think it will help you to fix your problem
Thanks
Iqbal
Posted on Mar 15, 2008
How to enable usb port LG 22LD330
On the desktop, right click on MY COMPUTER, and then select MANAGE option. a new window will appear, in that select SYSTEM TOOLS, in that click on DEVICE MANAGER, on the right side of the window pane, a list wil appear,
If USB is enabled in BIOS or EFI but the USB host controller does not appear in Device Manager (under Universal Serial Bus controllers), or a yellow warning icon appears next to the host controller name, then the version of BIOS or EFI may be outdated. Contact the maker or vendor for your computer and obtain the current version of BIOS or EFI.
If the controller appears in Device Manager, right-click the controller name and then click Properties. Problems and suggested actions are displayed under Device status.
USB ports have a separate entry in Device Manager. To check the device status, click Universal Serial Bus controllers, right-click USB Root Hub, and then click Properties. If you do not see USB Root Hub, you might not have a USB port installed on your computer
On the USB Root hub Properties page, it may tell you this device is working properly, or there is a Troubleshoot button. At the bottom you have an option to Enable or Disable the USB hub.
Jan 22, 2014 | LG Computers & Internet
There is a yellow exclaimation on my network adapter in device manager
This not necessarily cause for alarm. You can try to reinstall the driver for the device to see if that clears out the exclamation mark and, most cases, it will.
The exclamation mark simply means that Windows has found some sort of problem with the device. Double-click the adapter and see what the Device Manager's status says about it. This can, generally, point you in the right direction on what is wrong.
If reinstalling the driver doesn't work then post what the Device Manager status is for the device.
Jul 04, 2012 | Acer 91.AB370.001 Network Adapter
I have a hdd on promise supertrak ex4350 that has errors. There are 4 drive in raid5 config. The faulty drive is on port2. I replaced the drive but it still does not light up or show in the config. Not...
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Aug 30, 2011 | Promise SuperTrak EX4350 4-port Native...
Need help installing a controller
the drivers might be installed for this device
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
hope this helps
if you physically remove this sata ide card restart your computer then reinstall it this should activate the found new hardware wizard
http://download.cnet.com/windows-promise-sataii150-tx4/3000-18492_4-64684.html
Aug 06, 2011 | BYTECC PCI SATA Card with 1x e-SATA 2x...
No sound in a reformatted computer
HELP what are you asking in short
Aug 01, 2009 | Computers & Internet
Ethernet controller driver can,t be found
Hi there.
right click in the adapter with the yellow mark and select properties, look in the device status box, if it says code 10 the device cannot start then you installed the wrong drivers for the adapter.
Get the correct network controller drivers from here >>>>>>>>
http://support.acer-euro.com/drivers/notebook/tm_2480.html
If you still suffer the same symptoms after the correct drivers are installed then the device maybe faulty.
Good luck
May 30, 2009 | Acer TravelMate 2480-2153 Notebook
Usb ports not working
  1. Checking USB device status in Device Manager
  1. Right-click My Computer on the Windows desktop and then click Properties.
  2. Click the Device Manager tab to display the Device Manager window as shown at the right. (For Windows 2000 systems, click the Hardware tab and then the Device Manager button.
  3. In the Device Manager list, click the + sign next to Universal serial bus controller.
  4. Verify that a USB host controller and a USB root hub are listed below Universal serial bus. image002.jpg
  5. If Universal serial bus controller, USB host controller or USB root hub are not listed, close the Device Manager and go to USB port incorrectly configured in BIOS
  6. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a yellow exclamation point, go to USB controller IRQ conflict
  7. If you have Windows XP, right-click the Host Controller and select Properties from the drop-down menu. If you see this status message in the Properties window: The drivers for this device are not installed (code 28), go to Windows XP USB 2.0 driver not installed .
  8. If Universal serial bus controller, USB host controller and USB root hub are listed but one or more display a red X, go to USB controller or root hub disabled in Windows Device Manager.
USB port incorrectly configured in BIOS NOTE: The procedure in this section is intended for advanced users only. Incorrect BIOS settings could prevent your computer from starting or operating normally. If you are not experienced in making changes to your computer BIOS, consult your computer instructions or contact your computer manufacturer for assistance before attempting the steps below.
  1. Follow the instructions of your computer to view the BIOS settings. These settings are sometimes called CMOS settings or system setup.
  2. To view the BIOS settings, press a key, such as F2 or Delete, just after you turn on the computer. Instructions often appear on the screen briefly when you turn on the computer. Also check the instructions and manuals provided with your computer.
  3. Look for USB Interface or a similar setting in the Advanced Setup, Peripheral Configuration or another section of your computer BIOS settings.
  4. Follow the onscreen instructions or read the computer documentation to enable the USB port.
  5. Follow the onscreen instructions to save the new settings and restart the computer.
  1. USB controller or root hub disabled in Windows Device Manager
  2. Click the Device Manager tab. (On Windows 2000 and XP systems, click the Hardware tab and then the Device Manager button.)
  4. Click the line in the Device Manager containing the red X.
  5. Click the Properties button. (On Windows 2000 and XP systems, click Properties on the Action menu.)
  6. In the Communications Port Properties box, click the Resources tab.
  7. Re-enable the USB device by clicking the Enable Device button and follow the onscreen instructions.
Dec 28, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
K8T Neo Motherboard with Via and Promise SATA problems
http://www.versiontracker.com/dyn/moreinfo/win/140882
the above site has driver via Hyperion pro 11.5mb
http://www.soft32.com/download_170761.html
This one has promise fast trak driver
Hope this helps please post rating thanks
Aug 01, 2008 | MSI K8T Neo-FSR Motherboard
ERROR: code 28 -- Windows XP & USB 2.0
I'm unable to connect my western digital hard drive to my Windows XP computer via the USB port. When I check the USB 2.0 Controller in the Device Manager, there is a yellow exclamation mark (!) next to it. When I check on the status of the USB 2.0 Controller, the following message appears:
The drivers for this device are not installed (code 28).
What do I do now?
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 SE Digital...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
273 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
