Back to:
Tags:
Dynamode Networking Hub
Dynamode BR-6004 W G1
posted by immortalson on Mar 15, 2008
Hi There,
I dont know if I'm even askin in the right place, but I've been trying all day to find the default username and password for my Dynamode BR-6004 W G1 wireless router so that I can set it up.
Any idea what the usename/password are, and how I would reset it to start the setup process again?
Many Thanks,
R.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 28, 2008
FixYa! (100)
edhall
Rank:Guide Guide
Rating: 91%, 7 votes
Try holding down the reset switch on the back with the router turned on for about 10 seconds or more.
the following info was found at http://www.help2go.com/component/option,com_forum/Itemid,32/page,viewtopic/p,126642/
i believe the default password/username for your router is:
username:guest
Password:guest
www.portforward.com wrote:
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are guest. Click the Ok button to log in to your router.
this info was taken from
http://www.portforward.com/english/routers/port_forward ing/Dynamode/BR6004W-G1/WinMX.htm
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Dynamode BR-6004 W G1:
I don't want to Accept this solution
Can you Help with these Networking Hubs and Switches problems?
yellow steady, for a while after flashing all ports etc.
I have an N-tron 9000 that has two 9006TX's in the last...
lucas 7 SA seven pin need wiring diagram
hi, when i am trying to dial then after some time...
Got a call from a tenant that his thermostat was reading...
Loading problems.
Repair Service
Find Networking Hub and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
