Question about Panasonic Workio DP-2330 Printer
Fill i have a panasonic dp 2500 error e401
  • Paul Homuth
    Paul Homuth May 11, 2010
    that is a fuser error, most of the time it needs to be replaced
    Sergeant:
  • 284 Answers
It is a fuser error
Posted on Sep 22, 2008
Error e04-01 dp-2500
Service mode F9/ram initialize/fuser reset/reset power
May 17, 2014 | Panasonic Workio DP-3520 Copier
Error e401
This is a fuser warm up error. First check the thermistor if it is dirty clean it, check lamp & thermal fuse. Changing the thermistor &/or thermal fuse usually fixes this issue!
Nov 02, 2013 | Panasonic Workio DP-2330 Printer
How does this proplem occur? panasonic dp 2500 error e04-01
This error comes in fuser unit. the temperature is to low. Check the heater lamp, thermoswitch, thermistor and HTC board. Sometimes draping electricity voltage can cause of low temperature.
Mar 08, 2011 | Panasonic Workio DP-2000P Copier
How will i get the service key oprator mode to
the default key operator mode is '0000' but be very careful what you change in this menu thats the reason its locked so if you not sure about something make another post with details and i'll be able to help
Jul 08, 2010 | Panasonic DP-8035 Grayscale Copier
Workio dp 2500 everything is working properly no image on the drum the machine does not report any error
hi just cheq tha scaner lamp is glowing if glowing may you have problem in charge unit or charge crona
thanks
May 13, 2010 | Panasonic Workio DP-2000P Copier
WORKiO DP 2500 everything is working properly no image on the drum the machine does not report any error
yep!
For dp-2500 the common and usual problem is light or no image on print
and the common cause is the contact plate between drum and magroller. there must have a proper contact through that plate.
sometimes we also encounter the contact spring(3) of hvps going to process unit - misaligned position.
you may also check the tension spring of the drum (located inside the drum) if it has proper contact to the shaft.
... pls inform me if this still isn't helpful.
Mar 22, 2010 | Panasonic Workio DP-2000P Copier
Panasonic DP 2500 paper tray error
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 21, 2008 | Panasonic Workio DP-2330 Printer
What can I do to fix it ?
What is the problem first? Then maybe a solution..
Jul 21, 2008 | Office Equipment & Supplies
Panasonic 2500
e4 errors means fuser error, probably you encountered lots of fuser jamming.
the best thing to do is to ask your service provider to check your machine but for the mean time, you could erase the error log.
press function + orig. size + 3
press 9
find ram initialize
find LBP FUSER RESET
note: make sure that LBP FUSER RESET is the selected one
press set.
restart your machine
if you still encountered an e4 error, it means that there is a physical/hardware problem on your fuser unit.
i hope this could help u. : )
Mar 31, 2008 | Panasonic Workio DP-2500E Copier
Panasonic Workio DP-2330 Printer Logo
114 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
