Question about Canon PIXMA MP530 All-In-One InkJet Printer
Error is inner cover is open.
We cannot take print on canon mp530.after change the catridge this massage is appearing on display. " inner cover is open."
  • 3 more comments
  • Anonymous Apr 27, 2008
    I tried to follow your solution, but I see no black bar.  HELP!
  • amandaemery2 Oct 16, 2008
    i need to find out were is the inner cover
  • jglass06 Oct 30, 2008
    Same problem here- my "inner cover" feels a bit sloppy, like something isn't connecting with a sensor or something...HELP!!!
  • Anonymous Jan 26, 2009
    I have also followed yo instructions and can not find the black bar.
  • Drury Christian School May 13, 2013
    I have a similar problem with an iP4900 but it doesn't have the grey/black bar. Can anyone help?
  • 4,889 Answers
The "inner cover" can be seen if you open the paper output door, which you have to do to open the "printer cover" to get inside the machine and install the ink cartridges. The inner cover is a black bar right inside here. Push it up firmly enough , and it will snap up.
Regards,
Sai.
Posted on Mar 15, 2008
It's actually not a "black bar". On mine it is grey. It's an inside cover 2 inches above where the paper comes out after it is printed. I think when it is on the down position, it is used for feeding envelopes. But we need to have it flipped up.
Posted on Mar 24, 2010
I have had this error message and no matter what I do, the message won't clear and the printer will not operate. I have closed the "inner door", powered down, even unplugged it from the computer to reset. The message will clear when I restart, but as soon as I try to copy or print, it looks like it will work, but then I hear a slight click and the message comes back. The door isn't open, but something is communicating that it is. Anyone else have this problem?
Posted on Jul 31, 2008
  • dnocita Aug 02, 2008
    Solution #3
    posted on Jul 31, 2008
    dnocita
    Rank: Apprentice
    Rating: 0%, 0 votes
    I have had this error message and no matter what I do, the message won't clear and the printer will not operate. I have closed the "inner door", powered down, even unplugged it from the computer to reset. The message will clear when I restart, but as soon as I try to copy or print, it looks like it will work, but then I hear a slight click and the message comes back. The door isn't open, but something is communicating that it is. How can I get this message to clear?
  • Rick Beebe Dec 09, 2011
    Yes and I can't clear the error message either. Just posted the problem to Fixya.com--will see if there's any help there. Suspect it's a worn out/sticky microswitch that the senses the door status, but cannot locate without disassembly.
I kept getting the "Inner Cover is Open" message no matter what I did to the printer. I read and followed all the hints to no avail. I noticed in the lower left hand corner of the inner cover, if you take a qtip with alcohol and stick it in this space and it comes out full of ink, the problem is a inked up printer.
I had to buy the service manual to take the printer down to the print mechanism, and clean it as best I can. there is a waste pad there to catch ink, and ink does contaminate the whole area.
Clean this area, as well as you can. Use the Mrs' qtips, or buy the long qtips. Get plenty of alcohol also. The disassembly is not too dificult, but keep an eye on the number and location of screws.
I wish someone just would indicate the problem could be a dirty print mechanism. I admit that I used a few cartridges that I re-filled. This wasn't easy with Canon because the software would not recognize the ink level in the refilled cart.
Posted on Nov 30, 2009
I wish I could understand how you get this error to go away. I've had this printer for a couple of years and this has never happened.
When I lift the Printer Cover, there is a grey flap that you flip down to get at the ink. That is supposed to be the inner cover. I have this flap up... in the closed position... but continue to get this message.
I wish I understood what you folks meant by a "bar" that has to be pushed up. I can't find any such bar. I reached underneath where this inner cover flap is, and pushed up, but there doesn't seem to be anything there to push up.
I do see some ink splatter down underneath the inner cover...on the inside floor of the unit in the inside right corner. Maybe this is where that sensor one of you were talking about is located? Maybe the sensor is all fouled with ink?
I wonder if it's worth trying to get repaired somewhere or if I should just junk this thing.
Posted on May 27, 2010
Me too! I was worried I'd have to buy a new printer.
Posted on Sep 05, 2008
I had the same problem. Tried everything I could find on line and nothing. I was ready to replace the printer. I happened to wiggle and reset the paper supply and it started working. Worth a try.
Posted on Oct 04, 2010
It actually worked ..it was a flap inside the machine (near the ink cartridges) in the 'down position' and is the same color & texture as the outside of the machine. I thought it was a paper feed of some description, I returned it to the "up" position and bingo it worked...Thanks for your help.
Posted on Jun 24, 2008
  • smithsarum Oct 08, 2010
    this worked a treat, thank you.
I had the same problem, tried the solution, but the message did not go away until I powered off the unit and turned it back on.
Hope this additional information helps!
Posted on Mar 21, 2008
Canon mp530 error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement
Best of luck
Feb 19, 2011 | Canon PIXMA® MP530 All-In-One Printer
What does it mean when the alarm window says "inner cover is open"?
Closing the inner cover to clear error messages.
  1. Raise the Scanning Unit until it stops.
    (A) Press the Open Button to open the Paper Output Tray if it does not open automatically.
  2. Close the Inner Cover
  3. Close the Scanning Unit.
Nov 28, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 error code - "Check Printer 6500"
Hey welcome to fixya. Hope u 'll be fine
  • Properly seated
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
Apr 06, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My printer won't print because it says the inner cover is open. How do I close it.
The inner cover is the flap that you drop down to replace inks, there's a small switch on the right inside that goes bad, you can try opening and closing a few times, but you may need a shop to replace the switch.
Dec 08, 2009 | Canon PIXMA MP530 All-In-One InkJet...
If I want to print it doesnt work, info comes "inner cover is open" what can I do?
Hi Sir, This Inner Cover is actually the plastic door which is usually opened to install or remove the ink cartridges. This door or cover must be open or not properly inserted. Try Re-inserting it and set it Firmly.
Thank you Sir, Have a nice day.
Sep 25, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Getting the inner cover is open message when it is closed
i think you could not adjust printer cover properly.so we get many time this type of message in practs. becuse printer sencer are attached in cover and paper fedder and another parts. while they are not connec between them . they bring that type message.....thanks
Jun 16, 2009 | Canon PIXMA MP530 All-In-One InkJet...
CD printing error 'inner cover is open'
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
I hope it helps!!!
Nov 23, 2008 | Canon PIXMA MP530 All-In-One InkJet...
More than "one ink catridge installed" problem with new printer
Try a new Genuine yellow ink in it, if it fails take to canon dealer for free warranty repair.
Jan 12, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
12,649 people viewed this question
old marine
old marine
