I am trying to connect my toshiba laptop to my philips tv by vga but i do not know what settings to put my laptop on
  • 88 Answers
I'm going to assume you're using XP for this but if it's Vista it's a very similar process. I'm also going to assume that you already have the cable attached between TV and Laptop.
First you need to right click on your desktop and click properties. When the display properties applet opens select the right hand tab (settings) and you should now see two boxes representing your monitors.
Click on the right hand one which should be your TV and below that put a check in the box that says 'extend the desktop onto this monitor'.
Alternatively you can set your TV to be your main monitor by using the other check box but I wouldn't recommend this if your TV is CRT.
As for resolution, the slider should only go up to settings that your TV can handle.
Hope this helps,
erch.
Posted on Mar 15, 2008
    Scholar:
  • 141 Answers
Make sure that the video card of your toshiba laptop has a tv out feature. If it has, your tv should be functioning as your laptop monitor already.
    Brigadier General:
  • 6,966 Answers
Assuming that you have hooked the cables right, you need to press the key combination Fn + F? to activate the external video output of the Toshiba laptop. The "?" would depend on the exact model of your Toshiba. Additionally, there would be a blue lettered indicator on one of the top keys of keyboard indicating a monitor.
Incidentally, it might be worth mentioning that most TV can not operate on too high a setting of the Resolution of your Display Properties and therefore would require that the laptop's Screen Resolution be lowered down when used in conjunction with an external display device such as a monitor. At other times, the Screen refresh Rates would need to be lowered down also.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Video Not Supported
You would be better trying to connect from the laptop VGA to the TV Scart. But you will still need to set your laptop up to output a screen resolution that the TV can display.
Sep 19, 2013 | Televison & Video
How do I connect my Toshiba Laptop to my Sharp Aquos to watch Netflix?
you need to see if you have a pc in (vga )on your tv and then you need to see if your laptop has a VGA out then you need a VGA Video Monitor Cable HD 15 Male to Male cable bettween the lap top and the TV.
then you need to go to control settings on your laptop (depending on what operating system you are running) then display settings-settings and set it to go to your tv .
Jan 07, 2012 | Toshiba Computers & Internet
Can you help with connecting a laptop VGA to a philips hdtv lcd (model #32pf7421d) with a component cable? The laptop recognizes that it is connected, but nothing comes up on the TV except for...
Check your laptop with the same VGA cord on some projector or a monitor. If it works there, then there is a problem with your TV's VGA switching circuit. If it does not work, then there is problem with either the VGA cord or laptop's VGA port. To rule out the possibility VGA cord , replace it with new one. Please give the feedback for this so that further diagnosis can be done, if you are comfortable with the TV's electronics.
Aug 09, 2011 | Philips 32PF7421D 32 in. LCD HDTV
My problem is that when I try to connect my Toshiba satellite to my Philips TV using a VGA cable, I can only run it in save mode, which ruins the point. When I try to boot in normally, all I get is a...
Make sure your VGA cable works by using it on another computer or desktop just to rule out the possibility of a defective VGA cable. If the cable is good, then boot your computer as normal without the VGA cord and then once it is booted up, plug the VGA cable in, go to the start menu and type "multiple" into the search box. then click on "Set up your computer to use multiple monitors" and you should be able to fix it using those settings.
Hope this helps, Nathan Taylor
Jul 21, 2011 | Computers & Internet
I have a inspiron1300,and i wondered if it is possibe to connect it to my philips hdready tv.am sure which cable to use
You never mentioned what model Philips TV you have, however I've researched several and most seem to have a VGA video port in the back of them. If you have one of these (15 pin D connector) on the back of your TV you should be able to purchase a corresponding VGA cable (you'll want female pins on one side of the cable and male pins on the other side) and plug one side into the VGA port on your laptop and the other cable into the TV. Then use your TV remote to select that input. Should work fine!
See item 8 in the attached user guide link to see what I'm talking about. http://download.p4c.philips.com/files/4/42pfl3403_98/42pfl3403_98_qsg_eng.pdf
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 23, 2011 | Computers & Internet
I have a philips 37PF9946/12 tv and am struggling to connect my laptop to it, please help the laptop and tv both have vga connections x
The laptop should connect to the tv through the vga port. Just get a cable that is the correct gender on both ends and make sure the mode in the computer is set so that it outputs the vga signal from the graphics card. Maybe look in the control panel for settings.
Sep 30, 2010 | Philips Computers & Internet
Philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Feb 10, 2009 | Philips 52 In. LCD HDTV
Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Mar 22, 2008 | Televison & Video
Open Questions:
Which 5 Things missing your website? 1. Social Media Links Social media has become the foremost popular and best type of communication. With the recent announcement from Facebook that over two Billion individuals log in daily to use their website, it might be ludicrous to not faucet into this medium to achieve out to a wider audience vector-free-social-media-icons By using a simple to use social integration tool, websites will easily add this feature to share a message with their social circle quickly. 2. Clear decision to Action Buttons As shortly as you get a visitor to your website, it needs to be captivated to perform a relevant action. It may be a Call us Now button or a Sign-Up form for a free service trial, asking the user to act instantly. Netflix It should make sure that these buttons have the proper aesthetic attractiveness and appear at the correct time while not annoying the end-user. 3. Responsive web design The use of smartphone and tablets has quickly increased since 2012. Marketers corporations'and corporations'and firms} are currently paying shut attention to the present platform wherever fifty-eight of companies have a core mobile promoting team. responsive In such circumstances, a responsive web design is crucial to developing if businesses want to achieve profitable customers. A mobile-friendly website will permit you to compete together with your competitors and provides your business the boost to remain ahead. 4. Email marketing check-in Email marketing campaign could seem like an obsolete technique to stay up-to-date with your customers, however, of course, it can produce wonders for your business if used properly. email signup Placing an email subscription type will permit you to interrupt through the middle of promoting your services to an audience with revenue generating results. 5. Testimonials Word of mouth advertising is that the most credible means that of promoting your business. a region on your website containing remarks and comments of clients'the purchasers'the shoppers} you've got antecedently served will instantly gain the customer trust. test The client testimonials may be a way of gaining your website visitor trust by exhibiting a decent log of your past performance. confirm to focus on these reviews on your website somewhere close to your services section to realize effective results.
Feb 19, 2018 | Facebook Computers & Internet
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
