Question about Kitchen Ranges
The bulb in my hotpoint bs32 oven needs changing, how do i get the old one out. its not coming out easily, if i apply force i'm afraid i'll smash it.
    President:
  • 1,314 Answers
Turn the breker off and unscrew it wear a leather glove or use a rag or towel to protect your hand if it breaks we will go from there be sure to unplug or mturn the breaker off
Posted on Mar 15, 2008
Changing interior light on GE jvm1790
1. Unplug Oven
2. Unscrew 2 screws on top front of oven
3. Pull of front vent (might need a little force the
first time but not to much or you will crack
plastic)
4. Unscrew screw facing you near the front that is
attached to metal plate on bottom of opening
behind the vent.
5. Pull out metal plate (box) carefully not to
damage any wires.
6.Bulb is in this metal box, pull out old one and
press the new one's prongs into holes (be
careful and gentle the bulb breaks easily,
don't try to pull it back out to see if it's all
the way in or you will most likely pull a
prong out of the bulb)
just firmly press bulb
into place.
6. Screw metal plate back in place.
7. Plug in oven and test bulb.
8. Unplug oven again and put vent back on with
the 2 screws.
9. Plug in, set clock and your done.
The first time I opened it up was to look for the bulb. The vent needed a little pulling to come off. The second time (to put in new bulb) it came off easier and whole thing took about 5 minutes.
Hope this helps.
Just in case: I am not a professional nor claim to be. This is based on my own experience. Yours may differ. Unless you feel totally comfortable you should contact a licensed electrician or an authorized service agent.
Oct 18, 2010 | GE JVM1790 Convection / Microwave Oven
Can you think of reasons for a smashed oven door?
when oven is in self clean mode it reaches temps of over 300 degrees c. if a wet cloth was wiped on the glass it will smash
Feb 25, 2010 | Hotpoint RB757 Electric Kitchen Range
How do i replace the cooktop light bulb in my microwave oven?
I realized the light bulb was fixed using an adhesive (maybe a glue stick) that is why, I had a hard time removing the old bulb. After forcing it (and breaking the adhesive seal) I was able to replace it with a new one.
Oct 06, 2009 | GE Ovens
How to change the oven light bulb in a candy f245. Glass cover on inside doesn't seem to undo - moves a bit each way. No apparent access from outside.
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
Jul 15, 2009 | KitchenAid KEHC309 Electric Double Oven
Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Jun 29, 2009 | Neff B1421 Electric Single Oven
Can the oven door be replaced if it was smashed
Yes. Contact Hotpoint for the nearest servicing dealer. The door, if like most ovens, will simply lift off of the hinge stubs. The door must be in the partially open position, (the "catch" at 4 inches or so open) Replacement is reverse of removal.
May 31, 2009 | Hotpoint RB757 Electric Kitchen Range
My hotpoint bs32 oven went bang when I turned it on aftewr a while. I replaced the fuse and the grill and all the functions light up and work except the oven. The fan is working but the oven is not warming...
The fan oven element has failed, you need to replace it with a new element.
You need to remove the inner rear cover of the oven.
There you will see the element..
Unscrew and disconnect the leads and refit new element, be care ful not to lose the wires behind the element aperature.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Ovens
My bs32 built in hotpoint oven knob is seizing
If you can pull the knob off spray wd-40 into the aperture where the switch is.and try it again,if no better, then you will probably need a new switch.
Thanks.
Dec 18, 2008 | Ovens
Flames in oven are WAY too high! Having trouble lowering them.
Hi! melisrus
If you are using LP, even if you change the regulator settings from Natural Gas to LP Gas, the orifices all need to be changed. The Orifices should have come with the new unit, if not contact Hotpoint.
www.hotpoint.com
Make sure you order the instruruction manual and this is an Oven with Range Top, you will need orifices for all the burners on the range top.
InMrFixIt
Nov 18, 2008 | Kitchen Ranges
Changing the light bulb in the oven
the light bulb is screw type so turn only. with heat, bulb can jammmed over time so you may have to break it and get a pair of plyers on the cap. turn off power to do this
Apr 21, 2007 | Stoves Premier 720GRa Gas Double Oven
Kitchen Ranges Logo
85 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
