Question about La Pavoni Europiccola EPC-8 Espresso Machine
La pavoni 8-cup espresso
Hello. The basket will not go back on. It appears the filter that the water should pass through, is lop-sided. Is there anything I can fix from home?
Bob
    Problem Solver:
  • 5 Answers
Hi.
Will it go on at all? You should be able to turn it about 1/4 turn to the left once it's on. How far can you turn it, if at all?
I'm not sure which filter you're referring to, so I'll cover both:
1. There is a shower screen in the brewing group of the machine. You would have to look up into the group from below, in order to see it. This should be just a press fit, it's held in place by a big O ring. If it's lopsided, you should be able to just push it back up into place.
2. There is a filter that sits in the basket. It's the one that you fill with coffee. It should just sit square in the basket. If it's lopsided, take it out and you should be able to see why it won't sit in there properly.
Fergus.
Posted on Sep 08, 2008
SOURCE:
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
Virtually no crema :-((
If you have tried different coffees and grinds then i would try different packing methods using a tamper to do so. Try packing very firmly to not so firmly and see if that works. Also you might find that you need a new double filter basket. I have seen this in quite a few machines where the holes in the basket can become very slighty enlarged from what they were originally and what this does is allows the coffee to flow through the basket too quickly and therefore leaving you with poor crema by not getting a good extract from the coffee. I hope this helps.
All the best
Mr La Pavoni
Apr 23, 2010 | La Pavoni Europiccola EPC-8 Espresso...
Is water supposed to be added to the base and top chamber of the coffeemaker?
Only the base, then the water passes through the coffee as steam, re condenses and makes a great cup. Try and use specialty grade coffee,ground to mocha pot coarseness for the best results, not filter grind
Feb 10, 2010 | La Pavoni Caffe Mattina ESP-20 Coffee...
On a La Pavoni europicola which way do the piston seals get installed, both the same way or opposite to each other?
Normally on lever machines the top seal sits with the cup area(slash in gasket) facing up and the bottom facing down.
May 16, 2009 | La Pavoni Europiccola EPC-8 Espresso...
First Cup Is Cold From La Pavoni Europiccola
If the machine works great after the first cup then it is possible that the heat for your first espresso went to heating the portafilter or the cup used to brew into, try warming the portafilter first by running some hot water through it first.
Apr 09, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La Pavoni Duet replacement part
for water filter cartrige see this link:
http://www.espressoparts.com/results.cgis?catalog=&select=prod_desc&keywords=water+filter+cartridge&image.x=0&image.y=0
in the site mentioned above you can get other pavoni parts too. if you are not content i can give you another links too
Oct 31, 2008 | La Pavoni Club Combo Duet PA-1315 Espresso...
La Pavoni Europiccola EPC-8 Espresso Machine Logo
79 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Vitally Alcher
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
