my hoover AL 130 washing machine vibrates badly when loaded, like the load is off centre. It does not so this when run empty. I have checked the springs and dampers and they look fine. I also would have thought it would still have the problem when run empty if it was a spring or strut etc. I have read somewhere that there is a sensor that will stop the rotation and adjust for off centre loads. any thoghts??
-   It could even be the back of a spider bar has come away and has turned, trouble is this means taking the drum out and splitting. If you turn the drum until a bar is at the bottom and try rocking the inner drum, rotate until you hear it -   Guest
have u checked the bearings to do this u open the door place your palm on the front of the face panel and place your fingers on the inside of the drum and grab the inner drum and move your fingers towards your palm if there is movement then the bearings are gone and need replacing if there isnt then it could be the springs that are placed under the top they could be broken if not then replace your damper legs they may look ok but they will be down on pressure m
Was this helpful?
Yes
No
Popular Solutions for Hoover AL130 Front Load Washer
My hoover wdm 150 washer dryer will not dry. The drum spins as normal but no heat is generated. The...
(More)
My hoover wdm 150 washer dryer will not dry. The drum spins as normal but no heat is generated. The front reset button clicks when pressed after trying the dryer.
My hoover 6 express washer dryer has just started leaking from undearneath near the lint trap out...
(More)
My hoover 6 express washer dryer has just started leaking from undearneath near the lint trap out the front of the machine near the end of a wash cycle. Trap is clear, have ha dteh back off and all pipes seems well sealed and connected, it seems to leak from the solid plastic internal casing on the right hand side (as you look in from the back) and runs down the natural curve of the plastic dripping and forming a puddle that then leaks out the front underneath of the machine. Is there a way of fixing this problem , how do i get to it etc
error 2 has being cumming up on the screen some times but now it gets to the welcome screen and no...
(More)
error 2 has being cumming up on the screen some times but now it gets to the welcome screen and no progress also the express wash light and the select spin light are flashing and the time on the screen is also flashing
