Restore Toshiba to Out of the Box Condition If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition. 1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on your notebook. 2. When the machine Starts beeping; release the 0 key. 3. When prompted by the warning screen; select Yes to continue with the systemrecovery. 4. Select Recovery of Factory Default Software; click Next. 5. Select Recover to out-of-box state. 6. Click Next again. 7. Click Next to Start recovery. 8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Shut down the computer. Hold down the zero key and turn the computer back on. After a few moments, the Recover Utility will appear on the screen. Select the first option presented on the recovery utility. The option should be to restore an original factory image. This will erase the hard drive and reset the drive to the original factory state.
you need to tell the computer to move the signal over ---look for a picture of 2 tv screens on the laptop usually F5 or F8 (use with Fn key)otherwise right click on the desktop>choose PROPERTIES>SETTINGS
If you need to ask "how", I recommend that you STOP, and take the computer to a qualified technician, who can safely and correctly repair your computer.
to restore the factory setting you must boot the laptop off of the restore CD it will wipe the drive and reinstall the factory software and drivers just walk through the prompts. holding the f8 key will not restore the laptop to factory settings it just allows for options during windows startup
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
