Question about Mr. Coffee MRCTB Coffee Maker
The coffee could be hotter
When I first bought the machine the coffee was nice and hot when it first came out. Now it could be hotter. Should I clean it, replace elements or what?
Thanks
  • 833 Answers
Clean it. Use the manufacturer procedure. If that doesn't work, you can obtain a new thermostatic button. Outlet temp for most coffee makers is 180 F.
Posted on Mar 16, 2008
Why is the coffee not hot enough
Coffee should not be hotter then 98 degrees out of the machine. I have the same problem. before I brew I fill my cup with hot water and that helped me for a hotter cup of coffee. some machines allow you to adjust temperature, eg, Krups
Dec 13, 2014 | Coffee Makers & Espresso Machines
How can i make my coffee hotter?
The thermostat could be faulty, if still in warranty return else get a technician to replace it.
Aug 28, 2014 | Cuisinart DGB900BCU Grind and Brew 12Cup...
Coffee not hot enough
Ive had this machine for over 3 yrs now and agree the coffee could certainly be hotter. I usually blast hot stream from the milk jug by pressing the clean button for 5-10 secs. This does help. Also by having the cups heated up on top of the machine also helps. But i usually always give the completed coffee a 10 second blast in the microwave to get it to the temp i like. Its not ideal i know, but there seems no other way. Oh and make sure the temp is on high in the menu.
Dec 11, 2012 | DeLonghi ESAM6600 Espresso Machine
Coffee not hot
It is factory set and you have no manual control to override the settings.
Sep 18, 2012 | Keurig Special Edition B60 Coffee Maker
Hello We have a prima donna machine and
Check your programmed temperature setting; perhaps your machine has been set at low or medium.
Following are the instruction for Setting the Temperature from the manual for the ESAM6700.
1. Press the P button to enter the menu;
2. Press the < or > until "Set Temperature" is displayed;
3. Press the OK icon;
4. Turn < or > until the required temperature (high, medium, low) is displayed;
5. Press the OK icon to confirm (or the ESC icon to cancel the operation);
6. Press the button to exit the menu.
For a hotter coffee, before delivery rinse the appliance through by pressing the Rinse icon and confirming with the OK icon. Hot water
flows out of the coffee spouts and heats the internal circuit of the machine so that the coffee delivered will be hotter.
For an even hotter coffee, heat the cups by rinsing them with the hot water.
Mar 22, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Coffee not hot right after finishing percolating. But gets hotter with time, about 5 minutes.
Hi. you need a thermostst. You perking is turning off to soon, 1 it perks, so the main heating is working, It perked, 2 the keep warm element works because it is keeping the water hot and is making the water hotter. You can get the thermostat from repairshop.com.
It is a very, very easy fit and cheap part. Good luck Ron
Mar 08, 2010 | Faberware Coffee Makers & Espresso...
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
Coffee not hot enough!
You could replace the part but you might want to try a better brand like Krups or Braun
If you have a sentimental need to keep it you could have the thermostat and hot plate replaced
eric
Nov 14, 2008 | GE 106591 Coffee Maker
Bunn VPS 3
Are you leaving the machine plugged in all of the time? If not, you need to. The machine takes approximately 10 minutes to get to full temperature the first time then the water should stay hot from then on. Or it could be that you just need to turn up the thermostat. No, the water won't get hotter sitting on the burner and the coffee won't taste as good if the water you are brewing with isn't hot enough.
To get to the thermostat, unplug the machine and take the two screws on the top lid off. You should see a box that has a knob or a T sticking out of it. Turn it up a little bit, put the lid back on and let the heat up for a little while (10 - 15 minutes). Try brewing with just plain water. If it still isn't hot enough, repeat the steps above. Make sure you don't turn up the thermostat so much that the water boils.
Nov 06, 2008 | Bunn VPS Coffee Maker
Hotter coffee
can also - press menu untill temp comes up - set to high.
(only low med and high)
Mar 01, 2008 | DeLonghi EAM3200 Espresso & Coffee Maker
Mr. Coffee MRCTB Coffee Maker Logo
360 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
