Question about Acer X193W LCD Monitor
Monitor signal on monitor saying (input not supported) floating around the screen in a gray box. screen is black, with no response from computer. widows loads on screen when first starting computer, (no buttons on the monitor appear to work).
  • 3 more comments
  • tracygoes Jul 12, 2008
    Hi, I'm on a Mac laptop with a AOC 19" monitor connected.  I was setting the resolution and accidently clicked on the wrong one... should have selected the 1400x900 but hit another one,    not sure which.  Now I get the "input not supported" floater and cannot get back to any other screen... can't see the mouse/arrow etc.  I tried to download the driver fixer but got a message that safari cannot open it.  i unplugged and disconnected everything but still get the "input not supported" box.
    Any suggestions?  Is there a way to reset the res w/o needing to see anything on the screen?
  • WWEFreak666 Aug 01, 2008
    I switched the monitor from it being originally on Windows Vista to Windows XP, because I was having problems with the monitor (flickering, tinting and at times going completely black). Now I'm trying to put it back on it's original computer and now it won't connect.. Instead it says "input not supported".. I've tried restarting in safe mode by pressing F8 continuously through start up and get nothing, but the same message. If I don't get this to work, I am anyways going to get a replacement monitor VERY soon.
  • hmkallio Sep 03, 2008
    GREY BOX FLOATS AROUND, UNPLUGGED, PUT CD IN NOTHING WORKS
  • vanessen86 Mar 29, 2009
    Same problem. Tried both suggestions, but they did not work
  • snp_director May 11, 2009
    Monitor worked yesterday, came in this a.m. and monitor gives "input not supported" error.
    Aggravating!
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Posted on Apr 08, 2009
  • Acer Master
  • 19,396 Answers
Start windows in safe mode, pressing F8 key when required on startup.
in safe mode click on any empty prortion of your desktop (no icons, just background) with right mouse button to recall drop down menu.
Last menu command must be properties, click it.
It will open display properties.
Click settings tab at the top of display property box.
Lower down resolution so that your monitor will work.
regards
Posted on Mar 15, 2008
Input Not Supported: The Acer manual says to turn on the display BEFORE the computer. That must be done for plug-and-play to recognize the wide screen monitor.
Posted on Aug 21, 2008
  • 22 Answers
I have an ACER X193W+ monitor and this "Input Not Supported" error drove me nuts as well. Come to find out, the cable was bad. I connected another cable from another monitor and it worked fine. Try changing your cable.
Hope this helps.
Dan Hunt
Posted on Aug 01, 2009
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Cheers
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
Input not supported - floating gray message Win 7
You haven't specified what monitor you use but the gray message is most likely due to your screen not being able to handle the high resolution. Try setting it to a resolution below 1600 x 1200.
Best wishes,
Graemevm
Dec 15, 2009 | ZT Group Cisnet PC Desktop
Floating box
erm......reduce your graphic card output.
Sep 09, 2009 | Acer AL1916W 19" LCD Monitor
Input not support, Acer V193w
if the monitor is DVI conencted to PCI card, the computer will not see the monitor, on boot up, only in the Windows mode.
replace the DVI connecting with a VGA connection on the monitor, if there is no VGA connection on the monitor then you need to get a VGA monitor and connect that to theVGA port on the motherboard connector at the rear of the computer.
Apr 28, 2009 | Acer V193w LCD Monitor
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Mitsubishi diamond pro says "no signal"?
You have tried the monitor on more than one known good computer, yes?
I believe about 4" inside this monitor in the back the vga cable or connector connects to a board with an in-line connector. Can you see if this connector (internal to the monitor) in connected?
Good luck...
Mar 02, 2009 | Mitsubishi Diamond Plus 100E Monitor
FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Nov 12, 2008 | Computers & Internet
Input not Supported
Run in safe mode and try to change the screen resolution to 800x600 and reset your machine.
Oct 27, 2008 | Acer V193w LCD Monitor
Acer X243w monitor as a TV Pic great but "not supported" box
My assumtion is that the monitor is not displaying in 1920x1080 but has defaulted to a resolution that it can handle so as to display something. Step down the resolutions on the monitor until the gray box disappears. If you're satisfied with the picture your watching then hopefully you will be happy when you find the resolution the monitor is actually displaying.
Sep 19, 2008 | Acer Computers & Internet
How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Acer X193W LCD Monitor Logo
2,752 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
