Question about Microsoft Windows XP Professional
Problem in Windows XP sp2
Hi, Experts, Good wishes to all.
Please help me.
I am using Windows XP SP2. I am not getting folder option in tools tab. Even in control panel also there is no folder option. My 'C' drive is 9.75 GB occupied 6GB by means of programing files. But 'C' drive is showing free space 10 MB. Now, I want to check the remaining free space. But there is no folder option. How to check it?
  • dasara Mar 15, 2008
    Please help me.
    I am using Windows XP SP2. I am not getting folder option in tools tab. Even in control panel also there is no folder option. My 'C' drive is 9.75 GB and occupied 6GB by means of programing files. But 'C' drive is showing free space 10 MB. Now, I want to check the remaining free space where it is stucked. But there is no folder option. How to check it?
  • jitendra singh
    jitendra singh May 11, 2010
    Do you infected with funi.avi.exe virus
  • 1,006 Answers
Type the following text in notepad
REGEDIT
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoFolderOptions"=dword:00000000
Save this file as recover.reg [.reg is extension for regfiles]
Double click on it.
Log off is essential.
Posted on Mar 15, 2008
SOURCE:
How can i view hidden files in windows xp?
Kindly follow the following steps to view your hidden files in your PC...
1. Double click & Open the 'Windows Explorer / My Computer'
2. From the file menu bar select 'Tools'
3. Select 'Folder Options'
4. Select the 'View' Tab on the Option Window
5. In that tab you will find 'Hidden Files & Folders' with a folder icon
6. Select the 'Show Hidden Files and Folders' by selecting the radio button.
7. Then select 'Apply'
Now you will be able to view the hidden files & folders in your system. I have enclosed the screen shots for your better reference.
Jun 14, 2010 | Microsoft Windows XP Professional SP2
When i right click the option for sharing is not seen
Hi there, Dear user, this problem happens sometimes, the best option to install SP 2 (Service Pack 2 ) of Windows XP.
If you already have SP2, then turn on simple file sharing in Windows XP by following these steps.
a. Click on any folder and open it b. Click on tool menu and open 'Folder Options' c. Click on View Tab and find 'Use Simple File Sharing (Recommended)' d. Check the option and close everything. e. Its better to restart after that.
Once you restarted, put the removable media and right click there, and hopefully you will find the "Sharing" option there.
I hope this will help you and do write us about how did you go. Thank you
Regards Fahad
Jan 24, 2010 | Electronics - Others
I want to install xp sp3, but not sure.some people are saying its not worth it, or you get alot of problems. should i stick with sp2 or get updated to sp3? please help. thanks
sp3 is an essential download,yes you should get it .its bugs have been worked out.its also critaical to keep your pc safe from hackers and such.Shouldnt have a problem with it,but even if u did just uninstall it..
Sep 22, 2009 | Microsoft Windows XP Professional
My computer Desktop is not running.
Hi hichris_4u
You should be able to replace the Explorer.exe. Type in the command prompt expand C:\I386\explorer.ex_ %systemroot%\explorer.exe This will expand a new copy to the windows directory.
You should also download a new version of SP2 and reinstall it. You also could download a clean copy of SP2 Click the Download button. The file is 266MB. Create a folder on the C:\ root called SP2 and download it there. Create another folder called SP2 files now at a command prompt type C:\SP2\WindowsXP-KB835935-SP2-ENU.exe /x it’ll ask you to specify an directory so point it to the SP2 Files folder and let it extract there. Now type in the command prompt expand C:\SP2 Files\I386\explorer.ex_ %systemroot%\explorer.exe to expand a new copy to the windows directory.
If you get an error on destination, try expand C:\SP2 Files\I386\explorer.ex_ c:\windows\explorer.exe
If you expanding fron the I386 from the C:\ root try expand C:\I386\explorer.ex_ c:\windows\explorer.exe
If all fails, try and download SP2 onto another machine and then burn it to a CD for install.
Good Luck,
Mark
Mar 26, 2009 | Microsoft Windows XP Professional SP2
Problems copying a folder
eject the cd/dvd from cd-room and start copying .. when copy is finished put cd/dvd in cd-room and write these files to cd
all above actions done without any prgrams with Xp sp2
regards
zoser
Oct 20, 2008 | Microsoft Windows XP Home Edition
Integrate SP2 in WinXP CD
Step 1
Create 3 folders - C:\WINXPSP2 C:\SP2 and C:\XPBOOT
Step 2
Copy the entire Windows XP CD into folder C:\WINXPSP2
Step 3
You will have to download the SP2 Update, which is 250MB.  Rename the Service Pack file to XP-SP2.EXE  Extract the Service Pack from the Run Dialog using the command:  C:\XP-SP2.EXE -U -X:C:\SP2
Step 4
Open Start/Run... and type the command:  C:\SP1106\update\update.exe -s:C:\WINXPSP1
Click OK
Folder C:\WINXPSP2contains: Windows XP SP2
How to Create a Windows XP SP1 CD Bootable
Step 1
Download xpboot.zip  Code:  Code:  http://thro.port5.com/xpboot.zip
( no download manager !! )
Extract xpboot.zip file (xpboot.bin) in to the folder C:\XPBOOT
Step 2
Start Nero - Burning Rom.  Select File > New... from the menu.  1.) Select CD-ROM (Boot)  2.) Select Image file from Source of boot image data  3.) Set Kind of emulation: to No Emulation  4.) Set Load segment of sectors (hex!): to 07C0  5.) Set Number of loaded sectors: to 4  6.) Press the Browse... button
Step 3
Select All Files (*.*) from File of type:  Locate boot.bin in the folder C:\XPBOOT
Step 4
Click ISO tab  Set File-/Directory length to ISO Level 1 (Max. of 11 = 8 + 3 chars)  Set Format to Mode 1  Set Character Set to ISO 9660  Check all Relax ISO Restrictions
Step 5
Click Label Tab  Select ISO9660 from the drop down box.  Enter the Volume Label as WB2PFRE_EN  Enter the System Identifier as WB2PFRE_EN  Enter the Volume Set as WB2PFRE_EN  Enter the Publisher as MICROSOFT CORPORATION  Enter the Data Preparer as MICROSOFT CORPORATION  Enter the Application as WB2PFRE_EN
* For Windows XP Professional OEM substitute WB2PFRE_EN with WXPOEM_EN  * For Windows XP Home OEM substitute WB2PFRE_EN with WXHOEM_EN
Step 6
Click Burn tab  Check Write  Check Finalize CD (No further writing possible!)  Set Write Method to Disk-At-Once
Press New button
Step 7
Locate the folder C:\WINXPSP2  Select everything in the folder and drag it to the ISO compilation panel.  Click the Write CD Dialog button.
Press Write
You're done.
Oct 19, 2008 | Computers & Internet
About windows xp
Hi Ravishekhar, if you don't want to install operating system in own pc then i will suggest
process by process
(1) control panel
(2) user account
(3) guest on
(4) win+L.
(5) open the guest
now your solution is solved .
satyapal ,,,,,,,9934141768
Aug 08, 2008 | Microsoft Windows XP Professional With...
HELP ME
hi there my friend,
we have the hard way and then we have the easy way...
the hard way is to bootup with your bootable xp cd .follow the installation guide ..then.put in your key when you get the chance to ..and finish the installation. then apply service pack 2 to your installation .. and you're done...
the easy way would be to make a Slipstream Windows XP Service Pack 2 CD....which you can use each time you need to fix your system.
1 - Download the (full) "Network Install" of the Service Pack (English version [266 MB]), and save it to a directory (folder) on your hard drive (in my case D:\XP-SP2). Other languages can be downloaded from the Microsoft Download Web site.
Note: do not use spaces in the folder name!
2 - copy your Windows XP CD to your hard drive. Just create a folder (I used \XP-CD), and copy all the contents of your Windows XP CD in that folder.
3 - , open a Command Prompt (Start > Run > cmd), and go to the folder where you downloaded SP2 (cd \foldername). Type the command: servicepack filename /integrate:drive/path. In my example the command is WindowsXP-KB835935-SP2-ENU /integrate:D:\XP-CD.
Extract SP2 files
If you get the error:
This service pack can't be integrated error
This is caused by the fact that your Windows XP CD contains updates that will be automatically installed when you run setup. This type of CD's will usually be from larger OEM suppliers (like Dell, HP, or others).
You cannot use this type of CD to create a slipstreamed SP2 install.
First, the files will be extracted, and next they will be integrated in your Windows XP files:
Updating Windows Share
When ready, you should get a confirmation. Windows XP Service Pack 2 has now been Slipstreamed into your original Windows XP files.
Slipstream Completed
Creating a Bootable CD
For this part I used IsoBuster and Nero Burning ROM 6
After you install IsoBuster, you can choose to use only the product's free functionality for what we want to do, IsoBuster will look like the image below (you need to have your original Windows XP CD in the CD-ROM drive).
Start to extract the boot loader from the original Windows XP CD. Using IsoBuster, select the "folder" Bootable CD, and right-click Microsoft Corporation.img. From the menu choose Extract Microsoft Corporation.img, and extract it to the folder on your hard drive where you have your Windows XP files (D:\XP-CD in my case).
Extract Boot Image
Next, start Nero Burning ROM, and choose CD-ROM (Boot) in the New Compilation window. On the Boot tab, select Image file under Source of boot image data, and browse to the location of the Microsoft Corporation.img file. Also enable Expert Settings, choosing No Emulation, and changing the Number of loaded sectors to 4 (otherwise it won't boot!)
Nero Boot Settings
The ISO tab should be configured correctly as shown below:
Nero ISO Settings
If you have an older version of Nero you won't have the option Do Not Add ";1" ISO file version extention under Relax ISO Restrictions. You won't be able to boot your new CD, so update Nero!
You can configure the Label tab to your liking, I would however recommend that you keep the Volume Label the same as on your original Windows XP CD. Here are some (English) Labels:
* Windows XP Professional: WXPCCP_EN
* Windows XP Home: WXHCCP_EN
* Windows XP Professional OEM: WXPOEM_EN
* Windows XP Home OEM: WXHOEM_EN
Nero Label Settings
Next press New, and from the File Browser window, select the files and folders from your slipstreamed location (in my case D:\XP-CD). Now drag & drop the selected files in the ISO1 window.
Copy Files
Next, burn your new CD.
Burn
You now have a Bootable, Slipstreamed Windows XP Service Pack 2 CD!
Apr 28, 2008 | Computers & Internet
Folder option hide in xp
open my computer... at tools menu click folder options... then click view tab and click the button show all hidden files and folders...
Jan 21, 2008 | Microsoft Windows 98 for PC
Microsoft Windows XP Professional Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
