Question about Intel Motherboard
Motherboard crashed Hi, I have Gigabyte GA-K8S760M mother board and AMD 2800+ processor with 1GB+1GB PC2700 RAM. My motherboard crashed when I was trying to Flash the Bios. Can you suggest any alternative motherboard for this from any brand like Gigabyte or MSI that is available now ? Thanks, Regards, Tram
  • tram100 Mar 16, 2008
    Stuart,
    You are the best... Keep it up... thanks a ton :)
  • 807 Answers
The main thing is to find out what type the processor socket is.
Then buy a board with the same socket, and that can take the same ram type. This is your board so any equivelent should be fine.
CPU
  1. Socket 754 for AMD Athlon64
Chipset
  1. SiS 760 Chipset
  2. SiS 964 Chipset
  3. Super I/O: ITE IT8705 chip
  4. Integrated peripherals
    1. Realtek 8100C Ethernet controller
    2. Realtek ALC655 Audio AC'97 Codec
  5. Local Frame Buffer memory 64 MB
Memory
  1. Type: DDR400/ 333/ 266- 184pin
  2. Max capacity: Up to 2GB by 2 DIMM slots
Internal I/O Connectors
  1. 2 x Serial ATA connector
  2. 2 x UDMA ATA 133/100/66 Bus Master IDE connectors
  3. 1 x FDD connector
  4. 2 x USB 2.0/1.1 connectors (supports 4 ports)
  5. S/P DIF input/output pin header
  6. 2 x cooling fan pin headers
  7. CD/AUX in
  8. 1 x Game/Midi connector
  9. 1 x COM connector
Expansion Slots
  1. 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  2. 3 x PCI slots (PCI 2.2 compliant)
Back Panel Connectors
  1. PS/2 Keyboard / Mouse
  2. 4 x USB 2.0/1.1 ports
  3. 1 x VGA port
  4. 1 x RJ45 port
  5. 1 x COM ports
  6. 1 x LPT
  7. Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
CPU/AGP/DIMM setting
  1. CPU FSB adjustable via BIOS
Power
  1. ATX power connector and ATX 12V connector
  2. Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
Form Factor
  1. Micro ATX form factor
  2. 24.4 x 24.4 cm
H/W Monitoring
  1. System health status auto-detect and report by BIOS
  2. Hardware detecting and reporting for case open, CPU voltage, and fan speed.
BIOS
  1. 2M bit flash ROM, Award BIOS
Posted on Mar 15, 2008
WHAT GB RAM SOPORT IN DIVES
The Gigabyte mainboard you have uses DDR333, PC2700 RAM memory.
Your model GA-81845GVM-RZ has 2-slots and each slot can have up to a 1GB of memory, therefore you can have 2GB total RAM memory on this model mainboard.
I recommend mainstream, reliable pair of 1gb each memory modules such as Crucial.
Good Luck
Aug 31, 2011 | Gigabyte GA-8I845GVM-RZ Motherboard
Hi Could you please advise the type and size of
According to the manual, to max out the board's RAM you'd need to install 2 1GB sticks of DDR RAM. It can support DDR400/333/266. 2GB is it's maximum capacity.
Jul 09, 2011 | Intel Motherboard
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Recommend me a good gigabyte mother board.
Without anymore information, what your wanting to build the computer to actually do, Gaming etc...
Have a look at the :
Gigabyte GA-P41T-ES3G G41 Socket 775 8 Channel Audio ATX Motherboard
Jun 25, 2010 | Gigabyte GA-7ZX Motherboard
I installed the windows xp sp2 64bit, my system not good work. i used the gigabyte motherboard GA-MA78GM-US2H with AMD QUAD X4 PROCESSOR. not good working my system.. plz help me..
it should work fine .there may be woring instaling prosses. some high configreation computer not work it means in ashort periode xp- can crash as in 4 gb ram. please try sp -3 .it can help u.
Oct 25, 2009 | Gigabyte GA-MA78GM-US2H Motherboard
My AMD x4 processor problem with gigabyte motheraboard
please load windows xp 64 bit . it will work well.
also check the temperature of motherboard and processor in bios
if temperature high use good heat sink and cpu fan .
Sep 19, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
AMD Phenom II x4 920 processor works with a GA-MA790X-UD4P
Yes, that Gigabyte motherboard does support the Phenom II X4, for additional CPUs it supports check out the following website on the specifications tab:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387&Tpk=GA-MA790X-UD4P
Mar 12, 2009 | Gigabyte Computers & Internet
Memory up-grade
you can go max 2GB (1GB each) DDR333 PC2700.
you have to reset the bus rate to match the RAM speed.
if you stay with DDR266 then you don't have to reset the bus rate
Nov 13, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Gigabyte GA-81EXW memory chips
Any 184-pin ddr ram should work on this. You can actually use pc3200 (ddr 400) ram as well. Pc2700 ram is ddr333, and a higher speed ddr ram like pc3200 will work just as well if not better than pc2700, it will simply go down to the speed that the processor requests the ram run at. It's all backwards compatible, faster ram can run slower if the computer needs it to run at the slower speed. Depending on the price you can find as long as you get 184 pin ddr ram either pc2700 or pc3200 with work fine with your motherboard. Peter
Oct 02, 2007 | Intel Motherboard
Intel Motherboard Logo
261 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
