Where can I get a setup disc or where can Down load the setup program for a Linksys WRT54GS Router
Easy steps to set up the router
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Click Here to try step by step instructions.
Most of the users are now following this web site.
Http://www.linksysbycisco.com/APAC/en/support/WRT54G
Ok do not need drive, you access from browser type in address and login name password. Run Setup Wizard,and you will be good to GO, MUST download and read manual.
