Question about HP PSC 2110 All-In-One InkJet Printer
Scaner not sensing its home position and giving sound because motor not stoping
Some technician solving this problem by saudi rayal 80 but i like to know how it sensing it home position.
  • FbrTech07 Aug 25, 2008
    Same problem here. I removed the glass, cleaned both sides and the area with the white strip. Removed the scanner sled and cleaned all of the mirrors inside. Also cleaned the bulb and the lens of the CCD. The scanner head returned to "home" once but after subsequent power cycles it will not return again. I really like this printer and I don't want to scrap it. I also just bought $40 worth of ink for it so I really need to get it fixed.
  • 21 Answers
There is a white strip under the scanner glass on the right hand side, which indicates the home position, you need to remove the glass and clean the white strip, as well as the scanner mirris and optic lens.
Posted on May 12, 2008
Eror scaner in samsung laser printer cx 4300
  1. check scanner cable.
  2. check scanner home position sensor
  3. check belt
  4. replace scanner motor
  5. main board
Jul 25, 2015 | Samsung Office Equipment & Supplies
My hp 3390 is giving scanner error 6 message and this is following a power outage we experienced 02/09/2011. it wont scan, copy or send faxes though we can print and receive faxes. the scanner bulb moves...
this problem causes malfunction of CCD unit, observe that CCD unit moving both directions are not, its sensing the home position or not, even its crossing home position replace CCD, your problem will solve..Vinay...
Sep 05, 2011 | HP LaserJet 3390 All-in-One Multifunction...
My Canon MV 920 camcorder is unable to load any cassette not even a head cleaning cassette. Whenever I put a cassette in, after some motor sound the cassette is rejected. Please help me out.
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 03, 2011 | Canon MV920 Mini DV Digital Camcorder
Can't eject cassette
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Feb 22, 2011 | Canon Elura 80 Mini DV Digital Camcorder
How to solve bizhub 211 code error c0650
bizhub 211 error code C0F32, To solve this code simply replace the developer of the machine.
Feb 17, 2010 | Konica Minolta bizhub C250 All-In-One...
Sharp AL 1631 is flashing 1 L. What does that
Hi:
This might refer to your scanner assy being locked. The scanner assy is the unit under the glass that scans your document prior to copying it. Look inside the cavity where you pick up your completed copies. Look at the upper left corner and see if there is a knob there. If there is, make sure it is in the completely unlocked position.
Andrew
Aug 09, 2009 | Sharp AL 1631 Copier
Ice maker stoped working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
SCREEN BLINKING L2 ON SHARP AR-5316 E
L2 mirror sistem problem.Check mirror motor and mirror home position sensor.
Jun 04, 2009 | Sharp AR-5320 Black and White Copier
Minolta Di 1610 f not starting
Scanner home position. Check the scanner itself there is a small piece of plastic that actuates the home sensor, check for dust dirt (can air) sensor is loacated under the glass left side rear
Apr 27, 2009 | Office Equipment & Supplies
I have a problem in my canon IR105 it started with a paper jam at the finisher, when i solve that it gave me and error code : E000578-0002 and ask me to shutdown and restart so i did that, but the error...
The knurled belt motor is faulty. The knurled belt home position
sensor is faulty.
Condition
0001 The knurled belt motor does not return to home position when the
knurled belt motor is driven for 1 sec or more.
0002 The knurled belt does not leave home position when the knurled
Check motor and sendor in the finisher, if not solved - there are an technician required to set sensor, deatach the finisher from the copier & unplug their socket from copier and operate copier without finisher when technician not come.
Mar 04, 2009 | Canon imageRUNNER 105 Copier
HP PSC 2110 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
