Question about HP LaserJet 1018 Printer
Ink feeding how can i feed it with ink ?
Its a laser printer.
Posted on May 16, 2008
SOURCE:
Ajkill
  • 2035 Answers
SOURCE: Paper feed on Canon i 350n ink jet printer
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Posted on May 13, 2008
SOURCE: paper feed problems
tha only thing that you need to do is to put just a little oil in the bar that spends the cartidges not too much, this with the printer turn it off and moving with your hand slowly the carrier and puting at the same time the oil.
then turn it on the printer and then live it to do alone his own functions, and that`s it
regards
Posted on Jul 04, 2008
websnail
  • 419 Answers
SOURCE: flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Posted on Mar 13, 2009
myjosh007
  • 530 Answers
SOURCE: My printer will feed paper, but no ink is printed..
i im  josh in cebu phils.may i help you? Friend the printer that prints and without ink appears even though not run out of supply. the problem is not the ink  but the tank lever that carries the cartridge.there maybe stuck dried ink on it came from previous ink installed that drain on the lever. Solutions: 1. try to remove all the ink and clean the lever with a soft cloth. 2. go to settings and perform the head cleaning and nozzle check. 3. do the printing repeatedly until the ink comes out. thats all friend good luck hope i helped you.
Posted on Mar 14, 2009
HARDWAREGURU
  • 66 Answers
SOURCE: paper not feeding correctly
OPEN UR PRINTER N CLEAN IT USE AN ATISTATIC VACCUM OR CANNED COMPRESSED AIR . ITS HAVING THE PROBLEM THERE SHOULD BE DUST OR DEBRIS IN PRINTER . INSPECT FOR ANY BROKEN PARTS IN THE PAPER PATH . IF U FIND ANY TO INVESTIGATE OR REPLACING THE PRINTER.THANKS
Posted on Apr 18, 2009
Canon k420 copier
In some cases, not all; the paper feed rollers get dry and slick. If so they tend to feed at times and sometimes stop halfway at times. Look at your rollers.
Jan 17, 2014 | Computers & Internet
Red ink light blinking, won't feed paper. Have
this is hp security error, for ink cardtridge,(the ink cartridge has internal/acess counter), you need to try change cartridge, if contuinue send to hp service center
Nov 27, 2009 | HP DeskJet 940c InkJet Printer
Lexmark Z715 printer feed paper
The feed rollers might be dirty from the ink. Try cleaning them with a Q-TIP with a little isopropyl alcohol.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Lexmark Z715 InkJet Printer
Paper not feeding correctly
Apr 18, 2009 | Office Equipment & Supplies
Epson CX7800 3 in one printer feeds mulltiple sheets.
This is usually caused by a dirty or dented feed roller.
The feed roller is the black wheel that has s flat side to it above the paper tray. Try using a Q-tip and some rubbing alcohol to clean it. Then give it another whirl.
As with the ink on the paper. This is usually caused by leaky printheads. Epson printers are notorious for having the printheads die on them, but usually from the ink drying out. Check and see if the bottom of the printhead can be reached and cleaned by Q-tip or cotton swab. Give it a good cleaning using rubbing alcohol. Don't go over board as the alcohol will dilute the ink.
Mar 28, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Canon MP150
E23 is a paper feed error. Check the rollers and the paper feed mechanism. Following are the various error codes for your printer:
CANNON Printers MP150/MP160 ERROR CODE
E9 The connected digital camera / video camera does not support Camera Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
turn the printer off and lift  the front top and move the cartridge carriage manually at the center and then on the printer.
Mar 14, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Mar 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Flash feed paper & ink light my epson r1800 printer
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printer says paper jam and ink is finish
No it will be miss feed or feed mechanism broken...
Matt
Jan 22, 2009 | HP PhotoSmart C4385 All-in-One Printer
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
29 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
