My TV on AV mode doesn't show colours.
When I camcorder is plugged into TV and AV mode is pressed. The picture quality is very poor. no colours at all. Otherwise TV is good while using Settop box or playing DVD.
Help me.
  • 31 Answers
Let me ask you a question is the picture from the camcorder poor when the menu's of the camcorder are viewable on the tv also if you put the camcorder in record mode and just view a picture on the tv produced by the camera is it the same as the playback picture. let me know
Posted on Mar 17, 2008
  • 129 Answers
Good day.
Check for the settings of your cam, particularly the color system.
This also is a result of a poor tape quality which results in a poor playback resolution.
chris
Get a new lead
Posted on Mar 16, 2008
I am trying to playback videos on my JVC Everio Camcorder using the colored AV cords. I hear the audio coming through my TV but there is no video/picture. I have tried adjusting the settings and tried...
First, set [SWITCH TO ANALOG I/O] to [OUTPUT]
then turn off the (camcorder) unit.
After you connect the cable (from AV connector to the TV's AV Input Connector (accepting the 3 color cables), set the TV to VIDEO mode, selecting the AV input (from your Camcorder).
Then start your playback on the camcorder ...
slide the mode switch to select the (video) mode (instead of the picture/photo mode)... press the PLAY/REC to select the playback mode, and select the desired files/frames to play.
Hope this works for you. Have you tried using the HDMI mini connector instead ? (same process, just set your TV to accept input from the HDMI input)
Jun 03, 2014 | Video Cameras
Poor picture and colour quality on hd through hd box red is pink fuzzy hd picture
You need to check the resolution of your TV thru your input setting, try to check which will give better picture quality between 1080 or 720 settings. Also secure that your input setting as either HDMI 1 or 2 or 3, you can use the original remote and change setting by pressing input in cycle.
Jul 08, 2011 | Televison & Video
Camcorder is a Canon Mini DV ZR100 in very good shape. While recording with an AV plug into two DVD recorders and the firewire plug into a Macbook Pro, the picture seemed very poor out of the DVD...
that is normal its the copy protection that taged
on the dis toc.....that is why the picture go black and disturbing color/ disconnect your firewire try this..
Feb 24, 2010 | Canon ZR100 Mini DV Digital Camcorder
Picture poor quality no sound, can't access plug and play to re tune the unit
you can not enter plug & play in digital mode go to analog by pressing TV/DTV then menu plug & play will now be able to entered
Nov 05, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Screen is dark
AV/TV Button
Press ¡° AV/TV¡± button,the will be some word show on the right top
of the screen, press ¡° PROG+/-¡± to select the AV source, and then
press ¡° VOL+/-¡±to enter AV mode.
TV
PC
SCART
http://www.denver-electronics.com/UploadetFiles/154/25/DFT-1504_Black_English.pdf
The Tv is starting or going into PC mode Or scart mode set to TV mode. Hope this helps Please rate me. The link is to all of the setting for the TV. Blue light is pc led.
Dec 21, 2008 | Hisense LCD1504 15 in. Television
Poor quality picture while playing ps2 games?
i think you should try other modes too like pal and others or in many tvs there is a option auto so the tv automatically select the best mode of color itself.....
Jan 20, 2008 | Sony PlayStation 2 (PS2) Console
No sound
Go into the TV Menu and access the sound settings, for the UK it would normally be set to I. This MAY need to be changed to a different setting. Try the options that are listed. Might fix it!!
Jul 28, 2006 | Sanyo C40N
Recording From An External Device
The following Models can be used as a recorder to record from a VCR, TV or another Camcorder. 2004 - SC-D107 2003 - SC-D5000, SC-D27 2002 - SC-D180 Recording In Player Mode 1. Connect the camcorder to the VCR or TV with the AUDIO/VIDEO cable (provided) (to the A/V Outputs on External Device) 2. Set the power switch of the camcorder to PLAYER mode. 3. Turn on the VCR or TV. 4. Insert the blank tape with protection tab closed into the camcorder. If you want to record from a connected VCR, insert a recorded VHS tape into the VCR. 5. Press the MENU button, turn the MENU DIAL to highlight A/V and press the ENTER button. 6. Turn the MENU DIAL to highlight AV IN/OUT and press the ENTER button to select AV IN. "AV IN" and picture appears on the LCD monitor. OUT : Releases the INPUT mode. 7. Press the START/STOP button to set the camcorder to REC PAUSE mode. "PAUSE" appears on the LCD monitor. 8. Select the TV program or playback the VHS tape. 9. Press START/STOP button to start recording. If you want to pause recording for a while, press the START/STOP button again. 10. To stop recording, press the (STOP) button. Notes: * Recording from an analog VCR to the camcorder is only possible when the VCR is playing back at normal speed. * If you want to see the camcorder picture with a TV, set AV IN/OUT in the menu to OUT.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
