Question about Hi-Touch Imaging Technologies HiTi 730PS Dye Sublimation Printer Thermal Photo
Error Message appear when printin
It is almost two years i started using this printer but recently whenever i;m printing with this printer, i get a report; " Cam Platten Error" and my document fails to print. Please help me.
    Guru:
  • 126 Answers
U can't fix it with youself. I was ex. FAE for Hi-touch. goto hiti service station & ask to repair it. It need some tools to repair it.
if you will try it open it you will damage it.
Posted on Apr 06, 2010
    Problem Solver:
  • 4 Answers
Posted on May 05, 2008
SOURCE:
Error message
copy on my machine then i tray to copy
May 06, 2013 | Brother MFC-7340 All-In-One Laser Printer
I have my EPSON TX121 for almost 4 months and i installed it with CISS. I learn also to reset the waste inkpad counter and it work okay. My new problem is, the printer is starting again telling me a...
If you have a set of cartridges there try removing the CISS tanks and using them. If it recognizes the cartridges than the master chip on the CISS Tanks are faulty. Its usually the black.
Contact the manufacture for replacement chips if available.
I Hope this helps, if so please rate my response Thank you for supporting the FixYa Community
Regards GM
Apr 08, 2011 | Office Equipment & Supplies
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Lexmark 2480-100 stops printing after one page
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Lexmark 2480 Matrix Printer
Printer "out of memory"
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Error 0xc18a0106
Push OK, CANCEL, BLACK, & COLOR all at once while turning the printer off, turn it back on. I had to do this 2 times to get it to work and then it went through a long period of maintanence before I could print
Jun 23, 2008 | HP Photosmart 3210 Printer
CANON ip 4300 - 5100 error & prints skew onto DVD
I had this eror. It was caused by indexing error left to right.Would print some then cancel after starting to make clunking and left to right error gets to large.(white edge up the side of full page print).
There is a toothed print head carriage drive belt and a clear indexing strip above the heavily white greased bar behind print head carriage.
If this clear indexing strip gets grease or anything else on it the print head cannot index.
With print head at full right position,power off, I carefully wiped the clear strip by pinching between clean dry fingers and wiping up and down the strip a few times,maybe use cotton wool buds and IPA or methalated spirit if you can't get your fingers in there without breaking the strip. then with power on print head in change cartridge position,push carriage to far left and wipe right side of clear strip.I pushed carriage full left to right a few times,Then ran print head alignment.Fixed without taking apart.
Jun 23, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Epson 1800 error message -9672
try using only one type of connection (USB or FireWire) see if that helps.
no known conflict for DivX for the printer, not sure for the mac though
Jan 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Canon MultiPass F20 - "Wrong Cartridge error msg" - not new but hardly used
Take both cartridges out and then you will see a grey lever in the front of the assembly that holds the two cartridges in it.
If you lift that lever up it will allow you to remove the print head assembly.
Soak that in some hot water, use a straw to help blow out any remaining ink residue in the holes that the ink flows throw and once it is dry again put it back in and see if the error goes away.
I'm just running a head cleaning, nozzle cleaning etc. now but I appear to be back in business.
Mar 27, 2007 | Canon MultiPASS F20 All-In-One InkJet...
Hi-Touch Imaging Technologies HiTi 730PS Dye Sublimation Printer Thermal Photo Logo
297 people viewed this question
Top Hi-Touch Imaging Office Equipment & Supplies Experts
Pierre Legault
ray gallant
ray gallant
Tom Chichester
Are you a Hi-Touch Imaging Office Equipment and Supply Expert? Answer questions, earn points and help others
