Question about Gateway FPD2275W LCD Monitor
Monitor horizontal adjust no function
Monitor studioworks lg 452v horizontal adjust no funcytion picture bend both sides like an hour glass. video ok. what is the problem.
  • 151 Answers
It is the problem of horizantal section.Check horizantan hold transistor that is placed on hitsink of eht and two small transistors near iton pcb.and check horizantal yoke coil pins for dry soldring or low voltages.If thats are ok then change hori. &ver. deflection ic.
Hope this solution works.i am always for you
Posted on Mar 15, 2008
SOURCE:
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Jan 21, 2010 | LG Studioworks 775N 17" CRT Monitor
563A horizontal too wide unable to adjust, how to fix?
I HAVE LG CB563G MODAL15'' MONITOR HORIZOLY EXEED SCREEN I CANOT ADJEST WHEN ON MONITOR 1.1/2 HOUR IN
H/S C5803 TRASITOR FILES PLEASE HALP
Jan 15, 2010 | LG Studioworks 563N 15" CRT Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
LG Studioworks 452V LED's blinking
1. L O T Problem.
2. power supply out put problem
3. Drypoints at neck base.
Oct 21, 2008 | LG Studioworks 45 14" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
Horizontal and vertical adjustments
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
Mar 10, 2008 | LG Studioworks 45 14" CRT Monitor
Horizontal size is not working
1.In horiztal section R778 - 1Ohmsor 2Ohms one watt,R749 - 2.2k,R753 - 2.2kcheck it.
2.check Q716 - C3198,Q714- C3198 Problem Replace all thease componants.
3.and also check Damper diode DMV32 (or)DMV1500, it's related componants
4. dry points in horizontal section
Dec 29, 2007 | LG Studioworks 563N 15" CRT Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Shows nothing but cross horizontal bands
The monitor may not be able to handle the settings of the video adapter. If you boot into safe mode (tap F8 key as the computer starts), does the display appear correctly? If so, then you just need to turn down the settings (resolution, color quality, frequency) to the lowest possible settings. If the display still appears wrong, then it may be something wrong with the monitor. You can try connecting the monitor to another CPU and see if you can replicate the results.
Sep 14, 2006 | LG Studioworks 45 14" CRT Monitor
Screen also turned blue!!
check cable and resistor that is giving 2number pins signals to video amp. ic and driver of green signal.
Aug 15, 2006 | LG Studioworks 45 14" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
178 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
