Question about Akai PT4298HD Rear Projection Television
Akai PT4298HD problemo
I have the identical problem to what was described. Turns on, no picture, no sound, timer light, etc. I tried your solution of unplugging the red connector from the convergence board (I know I got the right one because I compared it to pictures of the actual board), plugged in the set, turned it on, and had the same problem. No picture. Not even a distorted one. Not even the "turning on" chime. But it turned on, and the light stayed on.
Any other ideas I should try? Is it possible the convergence board is the problem but your little test didn't work for some reason?
  • Shmoopy
    Shmoopy Mar 22, 2008
    Now the coolant has leaked onto the big board *under* the convergence board, where all of the inputs plug into. Turns out there was some coolant left in a spot I couldn't see from the back, but I got all I could find. Of course, that's what I said last time.....
    Anyway, what is this board and can it be replaced/fixed for cheap? I've never soldered squat, but I bought myself a multimeter thinking I might need it for this job in the beginning.
    Am I past the point of affordable fixability?
  • 4 Answers
I'm not a repair guy, just happen to have one of these TV's. Seems to me that unplugging the Convergence Board removes it from the equation and suggests something else might be the problem. I got most of my help from here and also from this thread:
http://www.tv-forums.com/forum/TV_Equipment_C4/Projection_TV_Forum_F24/Samsung_42_Convergence_problem_P4569/
The samsung TV is the same TV as this Akai, it's just a rebadged Samsung.
One important difference in my TV from yours. I did have a timer light, and with the back off, I could hear it power up when I plugged it in and turned it on. The timer light would flash then it would go off.
When I removed the convergence board, I could clearly see burn marks on the bottom of the board where one of the amps was soldered on. That gave me some piece of mind in ordering the part. I just scanned that other thread but remember some people talking about the power supply failing as well as the main board, you might pursue those avenues.
I wish you luck in fixing this!
Posted on Mar 18, 2008
  • retailguy Mar 18, 2008
    sorry, the link got chopped off. here's the complete one (you'll have to remove the line breaks)
    http://www.tv-forums.com/forum/TV_Equipm...
Akai pt4298hd
Look at AC power supply board they are bad about poor solder joints resolder thyrisitor on board.
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Only the red light comes on
Whats up Wade?
This is DVD MIKE with Perfectimagess.Try this first .Unplug the TV for a while and press the On/Off button which is supposed to perform a "reset".After that, plug the TV back in. It should come on and the Timer light off. The picture and colors might be distorted, but pressing the Perfect Focus button on the remote control resolves this right away.
The problems is a black picture or the TV won't turn on. The Timer light stays lit even though no Timer has ever been set. The colors converge and the picture is pinched. I don't think all of the expensive repairs are necessary, My TV did go out after a week of non-use while out of town (I was out of town, not the TV). I don't know. I'll post more if I learn more. I hope this helps Wade,
Vacuum the dust off of the circuit boards and inside the cavity. TAKE CLOSE UP PICTURES OF THE CONNECTORS BEFORE DISCONNECTING FROM THE CIRCUIT BOARDS. (IF YOU HAVE TO.) TAKE OUT CIRCUIT BOARD MOUNTING SCREWS. AND REMOVE THE BOARDS.
VACUUM THE DUST. LOOK- SMELL AND CLEAN THE GROUNDS, AND CAREFULLY CLEAN THE BOARDS. ASSEMBLE. DOUBLE CHECK CONNECTIONS WITH PHOTOS,
AND PLUG IN, TURN ON AND HOPEFULLY ITS ALL GOOD.
WADE WORK WITH ONE HAND AS MUCH AS POSSIBLE SON!!
DVD MIKE
May 14, 2009 | Akai PT4298HD Rear Projection Television
50" Akai rear proction tv
you may have a short in your poser supply best thing to do is take it to a shop and have them repair it
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Akai pt4298hd rear proj tv
Unit may be in timer mode. Check menu settings
Apr 22, 2008 | Akai PT4298HD Rear Projection Television
Double picture
Your convergence ICs need to be replaced. Its an easy job if you can solder. Let me know if you need any more info or a link to where you can order replacement ICs.
Apr 06, 2008 | Akai PT4298HD Rear Projection Television
Akai pt4298hd picture is to bright
Sounds like dirty lenses to me. Do some research on optics cleaning for RPTVs. AVS is a good place to start. Also try this:
http://www.keohi.com/keohihdtv/learnabout/generaltips/screenoptics.html
Mar 16, 2008 | Akai PT4298HD Rear Projection Television
Akai PT 4298hd
aliens... of course
To describe it, it is unaligned kind of like a 3D movie without the glasses. · http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 05, 2007 | Akai PT4298HD Rear Projection Television
Our tv will not turn on
Our AKAI was just 14 months old. A few days ago, it died also. Blank screen, no sound, but the timer light will flash on a couple of times when you try to power it up. It even sounds like it wants to turn on. I paid a tech to come to my house $65 and it turns out to be the power supply $385. I checked other chat boards and many people are having this same problem with their AKAI 42" (PT4298HD) televsion. A real piece of junk this model! Sorry for the bad news!
Sep 10, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai tv
have a good tv guy repace you convergence amp's john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
128 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
