Removing files from cd's I have burnt
Everytime a burn a cd on my laptop I then can't delete the file from the cd - it says it is read only - and when I try to change the read-only status it comes up access denied
    Guru:
  • 1,463 Answers
Hello bluepixie
if you are using cd-r when burning the files you cant delete the files as they will be read only , i would suggest using the cd-rw which you can re write over when need to .
riz.
Posted on Mar 15, 2008
  • 133 Answers
Most cd's are read only, that is u can only write on them but can't delete anything from them, unless u use the rewritable cd's if u want to delete a file.
SOURCE:
Tascam cd -rw 900 sl wont play cd burnt from my laptop
Make sure you are burning the audio files in a format it can read. The standered is Mp3, but some times you need to burn them in other formats.
Apr 05, 2014 | Tascam CD-A500 CD Player
When I started my pc i got the message " bad bios checksum. starting bios recovery. as I no longer have my Asus P4V8X-X support cd. I went to the asus website and downloaded the latest bios for this...
Instead of updating your bios try removing the bios battery and then wait for about 5 mins then plug it back in to reset it. Most often that fixes the problem faster and easier.
Aug 06, 2008 | Computers & Internet
How to delete songs
You cant delete anything once files are burnt to a disk.
you will have to copy the music to a folder then delete the music files that you don't want then you can add more music files then burn them to another cd/dvd
Click start click on computer to open you should see your drives C: and your other drives cd dvd and your phone E: or F:
Right click on the the music disk to open you should see your music
from there you select the music files right click on the music file/s select copy navigate back to the drive right click select paste or hold the mouse cursor the music file/s drag them to your
computer and paste them in usually in my documents my music.
May 07, 2013 | A Computer By Design Computers & Internet
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Remove read only from cd
The only way to change a file on a CD is to copy it to your hard drive, modify it there, after you change the attributes of the file from read only. Then re-burn the file(s) to a new CD.
Sep 23, 2011 | Computers & Internet
Hello i have sony AD-7240S cd/dvd drive it can read all cd/dvds but it cant read my burnt cd/dvds plz give me suggestion
there is something wrong with the format of the files that you burnt. its either the format is not recognized by your dvd player or the format is not supposed to be burnt.try reading every details whenever you're burning a file to a cd/dvd. at the same time, check the specifications of your dvd player and find out the formats that it can read or recognize so that you'd know what format should you burn a file into.
Apr 10, 2011 | Computers & Internet
No real problem just trying to figure out what kind of cd and dvd to burn with rw rw+ ect ect
R means write (yeah...) once the data has been burnt you cannot delete or change the files
RW means re-writable, the data can be burnt and then copied over again.
R+ and R- are specific for different types of copying, for burning data either disc format is fine
Mar 05, 2011 | HP G60-235DX Notebook
How to download mp3 music into the dvd disc
You can burn the mp3 music files to a DVD disc. Just burn the mp2 files as normal data files.
Some CD players can play mp3 music files but they need to be burnt onto a CD disc NOT a DVD disc.
Feb 26, 2011 | Computers & Internet
Cannot delete read only audio file from cd
You cannot delete a file from a CD-R or CD+R which is why it is a read only file. If you left the session open when you wrote to the disk you can add files to the CD. If you closed the session with your burning software it will fill the disk with blanks not allowing you to write any more files to the CD. You can Erase and Write to a CD-RW, but you will have to erase the entire disk and rewrite to it. You can copy the files to your hard drive and insert a new disk or erase the CD-RW and reburn the files excluding the one you do not want on the CD. Bottom line the CD has optical information physically burned on the CD unlike magnetic media it cannot be erased by rearranging the metal oxide making the file unreadable. Magnetic media works similar to an Etch-a-sketch where you can easily erase the image by shaking it. CD's and DVD's work like a canvas where you can paint easily, but you have to paint over the image or strip the paint to delete the image.
Apr 06, 2010 | Microsoft Windows XP Home Edition
Dvd drive WILL NOT read burnt dvd's or CD's
The problem occurs mostly when your drive is dying. I had the same problem with my laptop writer recently after which it completely stopped writing discs. Contact your support. Sometimes they would ask you to remove the upper and lower filters of an entry in the registry which would sometimes resolve the problem.
Jun 20, 2009 | Teac DW 28E CD-RW/DVD-ROM Burner
Open Questions:
Dell Printer support phone number +1=855=536=5666+ Dell Printer Customer Service QEFKEFU Dell Printer assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Dell Printer helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. Dell Printer TeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... Dell Printer Tech Support Phone Number +{1-855*536*5666*} to resolve all Dell Printer products. is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .Dell Printer CUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL Dell Printer CUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. Dell Printer CUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Dell Printer tech support pHoNe {18555365-666-}} nUmBeR USA Dell Printer tech support pHoNe Number {18555365-666-} to resolve all Dell Printer products. Dell Printer is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. Dell Printers Support Phone Number for Dell Printer Technical support help. Dell Printer Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 16, 2019 | Dell Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
