Question about Panasonic sa-ht930 Home Theater Audio System SA-HT930 System
Panasonic sa-vk925d - F61 error
I have just bought audio system panasonic sa-vk925d. There was power fluctuation and the error f61 flashed only once. All cotrol buttons on the radio were on but not responding/functioning. I tried to resert as directed in the manual but now only AC IN light is on please help.
  • kathy markovich Mar 28, 2008
    I was watching a movie last night, and everything worked just fine. I got home from work today, and tried to turn on the DVD system and I get an F61 error, and the system shuts down immediately. What is this and how can I fix it? HELP please someone
  • 4234 Answers
SOURCE: sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Posted on Apr 09, 2008
  • 5 Answers
SOURCE: my panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Posted on Jun 22, 2009
SOURCE: F61
That code means the audio amplifier IC´s are dameged and need to be replaced
Posted on Jan 23, 2010
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
dunnbiker
  • 8546 Answers
SOURCE: my dvd stereo system panasonic model SA DK2 , F61
F61 usually means the amp has detected a short.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Posted on Feb 21, 2011
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
AFTER A FEW SECONDS MY SYSTEM SHUT DOWN AND SHOWS ME F61 ON THE SCREEM
  1. AFTER A FEW SECONDS MY SISTEM SHUT DOWN AND SHOW ME F61 ON THE SCREEN
Oct 25, 2010 | Panasonic SC-AK300 CD Shelf System
Error F61 Panasonic SA-AK240
am o combina muzicala marca panasonic modelul sa-ak240 si imi da o error f61,dupa ce o aprind la nici un minut imi da error f61 apoi se stinge.din ce cauza ma puteti ajuta??veri.nice78@yahoo.com astept un raspuns
Sep 08, 2010 | Audio Players & Recorders
F61
Jan 23, 2010 | Audio Players & Recorders
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
My panasonic SA-AK57 it is displaying error code F61
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
F61 ERROR
The F61 code is a power amplifier or associated circuitry problem. You'll need to have the unit serviced as it requires test equipment and a trained technician.
Mar 15, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
F61 error
I had the same problem, and I had to replace the fan on the unit. The fan would not turn on at all, so the computer would tell the unit to turn itself off. After the fan was replaced (which is relatively simple) it works like new.
Dec 05, 2007 | Panasonic SC-AK78 CD Shelf System
376 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
