When i swithch it on it is fine and then i put a disc in and then it says loading and then it loads for a bout 10 seconds and then ust says wrong disc wen it not
  • Anonymous Apr 25, 2009
    dvd player wont play dvd
  • 979 Answers
A problem with your optical assembly has reared its ugly head...accordianman
Posted on Mar 17, 2008
6ya staff
SOURCE:
My 60kva deutz diesel generator trying to run down when i put it on load,in which it has been carring same load before
It sounds like some thing is shorted internally which would caus the generator to draw more current and load down.
May 21, 2014 | UST GG2300 Portable Gas Powered Generator
Plaer sayes loading and then after 10 seconds says no disc
Dirty disc? Wrong format disc? Dirty laser assembly in player?
Jan 07, 2011 | Televison & Video
I just purchased a 2006 Pathfinder and at 1st felt like an idiot because it wouldnt load my disc so after a few different disc and even reading the manual I still cant get a disc to load. should it really...
after choosing the disc # put the disc in about 1" and it should take it out of your hand and into the machine DO not try to push it in...
if you do it will stop/reject the disc...
Sep 16, 2010 | Nissan Pathfinder Cars & Trucks
Loads cds. I can hear the loading mechanism operating, I get the 'read' message, but 10 seconds later comes the error message
either the cd you are trying to use is in the wrong format for that cd player or something is wrong with the eye in the cd player
Jun 10, 2010 | Sony CDX-565MXRF 10-Disc CD Changer
''Wrong Disk'' error
KM,
You'll need to check the region code of your player.
Make sure you have no discs in the player, and unplug the unit.
Plug it in and turn it on.
Open, then close the tray (with no disc!)
Press the Setup button, then select Load Setup
Press the Enter
While it it loading, press Menu.
When the box appears with a number, confirm it says 1 (region code 1 = USA). If it doesn't, please change it to 1 using the Up / Down buttons.
Press Enter to accept the change.
Jul 07, 2009 | TruTech DV288B3 DVD Player
Wont load games
sounds like it could be a dirty lens buy a lens cleaner disk (bout 10 bucks) this should fix your problem
May 28, 2009 | Sony Playstation 3 (PS3) Console
PSP
try 2 take the disk outof the plastic cover get a damp cloth wipe it very smoothley and then put ontop of a boilerfor a bout 30 mins then put it back in the plastic cover then try it
Apr 01, 2008 | Sony PlayStation Portable (PSP) Console
Disk wont load.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
169
Nov 30, 2007 | Nintendo Wii Console
Samsung 3650 dvd/vcr player loading problem
Sorry, no suggestion other than don't buy Samsung. That's my conclusion after owning the same model. It worked fine for a while, but now won't load any DVD... usually. Sometimes it will play one, but more often it won't. Mine tries to load ("Loading") for a long time, I hear the DVD spinning, then ultimately the screen displays "This disc cannot be played" or something to that effect.
Nov 25, 2007 | Televison & Video
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
