Question about Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard
2 x 2GB Kingston CL5 detected as 1 GB each one
I installed recently 2 ram modules Kingston 2GB CL5 (4 GB total). The problem is that in BIOS it only detects 2 GB (1 GB for each one), I mean, half of real memory. Rams are OK ´cause I could test them before in another computer, so when I install it into my motherboar it´s only detected 2 GB. Dual channel is detected correctly so i´d like what happens.
I called to my motherboard provider so he told me they have had too many problems installing ram modules into asrock motherboards, so I wondered and said that kingston is not a vulgar trademark so he reiterated to me the problem is in ram assembly (?¿?¿?) and asrock would say "this is an incompatibility of ram" (I don´t believe this at all).
P.S.: I updated my Bios to the 2.20 version and the same results than before. Ram modules are KVR800D2N5K2/2G each one. I run windows xp (this is not important) so I´m tire to check the Bios with no result.
Thanks.
Thanks a lot.
  • kauffelt Mar 16, 2008
    Thanks a lot, but I tried everything possible. I tried to install only 1 module (in every slots) with no result. RAM modules have been tested in other asrock motherboard and worked fine :(
    Thanks again.
  • Anonymous May 11, 2010
    Plz give details about ur motherboard. (model number,etc)
    Problem Solver:
  • 5 Answers
Ok, I got it, Ur motherboard supports upto 8GB DDRII Dual channel
Try using these RAMs on other slots of the board to check if there is a problem with RAM Slot (As there are four slots on ur board).
If no success, try using RAMs on some other system to confirm whether problem is with RAM or Motherboard.
Posted on Mar 15, 2008
SOURCE:
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
Dell precision 670. Adding 8 gb total memory. Using Kingston KX1563-NAB; DDR2 2gb 2Rx4 PC3200 EEC, registered. Accepts 4 gb in dimms 1 and 2 (2 gb modules) and boots fine. Adding 4 more gb in dimms 3...
glenn_mullin
From what I can tell the Dell Precision Workstation 670 does support over 4GB of RAM. However when you have over 4GB of RAM installed in the system you have to have the Memory Cooling Shroud connected to keep the memory cool. Also this is only shipped out when the system is ordered with over 4GB of RAM originally. If you do not have this part you can order it from Dell buy calling 877-671-3355.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jan 27, 2011 | Dell Precision Workstation 670 PC Desktop
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Its a NVIDIA nForce2 with dual channel DDR & USB 2.0 It has two slots one purple one green. I have replaced the 2gb sticks and it no longer beebs but won't boot and monitor says "no input" replaced the...
From the information you sent, I can't figure out the exact make & model of your motherboard, but I would guess that it supports a maximum of 2 GB of RAM. So, I would suggst you try to install 2 RAM modules, each of them 1 GB in capacity & see if this works.
From my previous experience, most motherboards with only 2 slots for RAM modules support only a maximum of 2 GB RAM total.
Nov 04, 2009 | Kingston 1GB PC2700 DDR DIMM Memory
Acer Extensa 5620Z will not work with more than 2GB RAM??
parrotheadpc is incorrect in stating "you can only have a total of 2048 mb installed".
the 5620Z accepts 2 x 2 GB SODIMM RAM, the machine boots and shows the full 4 GB in the BIOS.
the full 4 GB works with the Ubuntu x64 installer.
Windows XP x32 goes BSOD on startup.
Windows 7 x64 install from DVD fails with same BSOD error.
conclusion: this is a Windows-Extensa 5620Z incompatibility that would require a fix by ACER at the BIOS level.
question: there may be specific memory modules 2 x 2 GB which do work--anyone have it work with Windows?
Oct 02, 2009 | Acer Extensa 5620 Notebook PC
Extra ram for hp550
1.Make sure you have purchased and installed the correct memory .A check of the spec. lists 667 MHZ DDR2 SDRAM
2. If you have try to reset it in the laptop.
BIOS should be OK specs indicate you can increase up to 4 Gigs.Good Luck.
Sep 15, 2009 | Computers & Internet
ACER 9410-4933 LAPTOP ? Won?t boot with 4Gb CRUCIAL RAM
YES THE FREQUENCY OF BOTH RAMS DO NOT MATCH ... THATS BOOTING WITH EACH BUT ONLY ONE BY ONE ... YOU NEED RAMS OF SAME FREQUENCY AND SYSTEM WILL SUPPORT BOTH OF THEM TOGETHER ...
Sep 16, 2008 | Computers & Internet
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Asrock ALiveNF6G-VSTA (MB-ALVNF6G) Motherboard Logo
331 people viewed this question
Top Asrock Computers & Internet Experts
Ekse
Thomas F. Schneider
Joe Negus
Joe Negus
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
