Question about Mitsubishi VS-50111 50" Rear Projection Television
TV will not stay powered up.
TV turns on with green light, then turns off. When I hold menu and input I get 2-4 with the lights. Any suggestions?
    Sergeant:
  • 395 Answers
2 - 4 is vertical deflection protect replace the vertical IC or look for bad solder on the vertical IC
Posted on Mar 16, 2008
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Have Hd 1080 series tv model # vs-50111 tv will not turn on. When you try to turn it on green light stays on for 3 seconds then nothing.
it may or may not have the self check but try this:
When green light comes on and goes off ON THE FRONT OF THE SET press and hold the menu and input buttons at same time for 5 seconds or more and release both.
Power light should blink a two digit error code like 2 blinks, 2 blinks and pause--repeat it several times--all their sets after 1999 have this feature.
If yours does not someone has to go inside and measure voltages etc to find problem---a lot of the older ones develop broken solder connections and the chassis would have to be examined for that.
SD TECH
Apr 22, 2012 | Mitsubishi Televison & Video
Tv will not stay on
If an older rear projection Mitsubishi: When green power light comes on and goes out do the self check for errors.
Press and hold both the input and menu buttons at same time on front of set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know if you find an error code and I will tell you what it means.
Mar 01, 2012 | Mitsubishi Televison & Video
MY TV WONT STAY ON. WE TURN IT ON IT TURNS OFF. WE DID THE RESET SYSTEM BUTTON.
when it shuts off and power light goes off do the self check this model has.
When green light (power) goes out, on front of set press and hold both the menu and Input buttons for at least 5 seconds and release both.
WATCH THE POWER LIGHT closely, the light should blink a two digit error code.
for example, 2 blinks, 2 blinks and a pause, it should repeat the code at least five times.
Let me know what code you detect and I will tell you what it means.
SD TECH
Feb 12, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The tv just turns off after about 5 seconds and won't stay on. i've used the system reset and unplugged it already. no power surge, lightning storm, etc. Ideas?
If reset does not cure it and if after about 70 seconds of unplugging set the green power light stops blinking, do this:
When power light comes on and goes off, on the front of the set press and hold both the menu and input buttons at the same time for at least 5 seconds and RELEASE both buttons.
Power light should blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it four more times.
Let me know what error code you find and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My tv green light comes on but then turns back off cant watch tv why is that
when you turn it on and then the green power light goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for at least 5 seconds and then release both.
The green power light should blink a error code at least 5 times: most common is 2 blinks, pause and 2 blinks----
Let me know what error code you find and I will tell you what it means--2,2 is the most easy to fix and common.
SD TECH
Aug 03, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I have a mitsubishi 1080 series tv. I turned the tv off and then I went to go turn it on, now the little green light on the tv stays on for 2 sec. and then goes away without the piture ever coming on.
A hint--if the green power light comes on for a few moments and goes off do the self check this set has.
On the front of the set press and hold BOTH THE MENU AND INPUT (OR DEVICE) BUTTONS BOTH FOR AT LEAST 5 SECONDS. Release both buttons and look at the power button.
If this is the case the power light will blink a two digit error code--most common in this case is 2 blinks, a pause and 2 blinks--it will repeat the code up to ten times.
Let me know if you find an error code or the power light just blinks and never stops.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Tv WONT STAY ON
When the power light comes on and then goes off perform the self check feature the model you indicated has:
On the front of the press and hold both the MENU and INPUT (DEVICE) BUTTONS both for at least 5 seconds and release both buttons.
The green power light should blink a two digit error code--most common is 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
