Question about SanDisk Sansa Clip MP3 Player
Somehow i deleted everything!
Now my puter wont recognize it and the files that were there it says are empty is it possible to reprogram this thing
  • 8,596 Answers
There are a few different ways to delete songs off your player - see especially the method involving the firmware update.
Preventive Medicine: To prevent Windows Media Player from adding all of your My Documents files to the Sansa player every time you connect the Sansa to the computer - Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Set up Sync". When a window pops up, uncheck the box that says "Sync device automatically".
Quick Method 1 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Quick Method 2 - Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Slow Method, allows more control over what gets deleted: In Windows Media Player 11, the files are organized by Music, Pictures, Videos, Etc. First, you will want to plug the Sansa player into the computer. Then click the Library tab in Windows Media Player. You will most likely be in Music view. You will see two sets of folders in the left-hand side of Windows Media Player. The first set are all the files stored in your computer. The second set of folders underneath the line that says Sansa 1GB Mp3 player (I forget the exact wording) has all the files that are stored in your Sansa player. Click on the "All Songs" folder. You can individually delete all the songs that you want by left-clicking once on the song name in the middle of the Windows Media Player window, and then pressing "Delete" on your computer's keyboard. You will have to repeat this process again for images, videos, etc by clicking the little arrow next to the picture of the musical note on the upper left hand corner of Windows Media Player, and expanding the dropdown menu, and selecting "images"...then "Videos" etc.
NOTE: After plugging in your Sansa player, if you see a message that says "Connect a Device" in the Sync tab on Windows Media Player, then the cmputer is not properly recognizing your Sansa player, and you may need additional instructions from me.
-Tha Mp3 Doctor
Posted on Mar 17, 2008
SOURCE:
How can I get the pictures back, after I've deleted them and emptied the waste bin?
If you have emptied the trash your only hope is to use Recovery software such as Wondershare, or Data Rescue. These are third party programs designed for data recovery in your situation.
Sep 13, 2014 | Apple MacBook Pro with 17" Display
Canon copier imagepree C1 Throwing E060 codes any suggestions
i WOULD completely UNINSTALL PROGRAM...delete "PROGRAM FILE" ASSOCIATED WITH SAME, IN "PROGRAM FILES"..."EMPTY TRASHCAN"...RESTART" puter...DEFRAG...RESTART puter...RE-INSTALL program...Simply put, START FROM SCRATCH !!!...OPEN "SERVICES", in "CONTROL PANEL"...RESTART "WINDOWS INSTALLER" AND BOTH "RPC" services...BEFORE RE-INSTALLING THIS PROGRAM...Then, after re-install...RESTART AGAIN...See if it now works...While RE-installing, fill-in REGISTRATION info also...Should fix your problem...Let me know if this works, k?
Feb 21, 2012 | Office Equipment & Supplies
Where did all my disc space go?
Empty your "Recycle Bin" -- it's possible that the files have just "moved" from their original location, and have _not_ really been "deleted".
Or, right-mouse click on "My Computer", and choose "Manage". Click through "Disk Management (local)", and you'll be able to "delete" the partition(s) on the drive, and then "create" a "new" partition, which, of course, will be 100% "empty".
May 07, 2010 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Maxtor harddrive not being recognized
It sounds like somehow your Hard drive has been formated. You may possible also have hardware failure.
Good luck. Hope this helps
PLease rate
Apr 10, 2009 | Computers & Internet
Scandisk cruzer - system files deleted
Hi ,
You can Uninstall the U3 system , link to uninstaller can be found at : http://www.u3.com/support/default.aspx#CQ3
once you uninstall it you can go back and reinstall the U3 system from the same website.
Jan 29, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
A dlna protocol error 7531 has occured and doesnt play any of my games or dvds
For me I was using PS3 Media Server which had somehow become corrupted (possible power failutre).
Uninstall PS3MS, then MANUALLY delete remaining files and folders (important). Then re-install PS3MS.
this solved it for me after trying everything else possible.
Aug 31, 2008 | Video Game Consoles & Games
FILE ISSUES
You can format the whole player..and that will delete everything off the player...use windows media player to format the player....once you format you shouldnt have any songs in there...
Dec 30, 2007 | SanDisk Sansa E280 MP3 Player
Wheres the music?
Put the player in MSC mode
Plug in
go to My Comp
go to tools
go to folder options
choose view tab, then choose SHOW HIDDEN FILES and hit apply
once you choose OK you should see the folder Music,
open and delete at will like you would any file: highlight, rightclick, delete.
You can also format in MSC mode by rightclicking on player in My Comp and choosing Format
Oct 14, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
181 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
