Eating tapes My tape deck is eating tapes. It looks like there has been some milky-like substance was spilt into the front. Besides the obvious cleaning; Is there an adjustment or other repair?
    Scholar:
  • 49 Answers
Chances are that that "milky substance" has gummed up the works. Sounds like the pinch roller (the rubber wheel that draws the tape through the machine) may have gunk on it, so when you put a tape in and push play, the tape sticks to it, and simply wraps the tape rounmd and round.... eating the tape - as you say. The capstan SHAFT (see below) could also be dirty. Another possibility is that the take up spool (in the machine) is gunked up so it won't turn - so that the tape is spooled OUT of the cassette and is scrunched up inside the machine and the machine eats it.
There are OTHER scenarios, BUT ALL (including the above) require taking the machine apart and throughly cleaning it with alcohol (or - depending on what you're cleaning - even soap and water!).
Cleaning the capstan pinch roller and the capstan SHAFT concievable could solve your problem. The capstan shaft is the shiny metal shaft that pulls the tape through; the pinch roller "pinches" the tape AGAINST the capstan shaft which is how the tape plays.)
It's hard to "get in there" to do this cleaning (not to mention even SEE what's going on) short of taking the mache apart.
Posted on Mar 15, 2008
Cds skip on first songs tape deck eats tape aiwa 3300
I AHVE THIS SAME SYSTEM, YOUR LENS ON THE CD PLAYER NEEDS TO BE CLEANED, AND THE TAPE ROLLER AND CAPSTAND NEEDS TO BE CLEANED, OR MORE THAN LIKELY, THE BELTS NEEDS TO BE REPLACED.
Nov 30, 2012 | Aiwa NSX-A777 Shelf System
My sony tc k96r is eating tapes
It needs to be serviced by a Technician. Look up Skywave Tape Deck Repair in Chicago area if you want it fixed.
Oct 02, 2011 | Sony Audio Players & Recorders
Wr565 - both decks jam the tape when i play them. any suggestions?
rss13506,
I'm not sure what you mean by jam but I bet you need to clean the head, roller and pin in each deck. Use rubbing alcohol and a q-tip to clean the:
1) Head (silver thing in the center bottom where the tape slides over; it produces the sound).
2) Roller (black wheel thing that keeps tension on the tape).
3) Pin (above the roller-works with the roller).
If any of these parts are dirty the deck will eat up the tapes. Clean them even if you do not see visible dirt on the q-tip as dust does not show as well as oils in the air typically from cooking will gum up the parts. Give them ample time to dry before trying a tape.
As any tape playing person knows from the 70's and 80's-try a tape you don't care about first, to make sure the deck will not eat up the ones you like!
-Chris
Sep 06, 2010 | Sony CASSETTE DECK Single Dual Cassette...
Both decks eat tapes when fast forwarding, normal play is OK
it never eate tape in ff or rew mode . look for back tenssion
Jun 21, 2010 | Sony TC-WA7ESA Single Cassette Deck
Eating tape when I try and record or rewind tape
its sounds like the tape deck needs to be cleaned
Apr 13, 2010 | Canon GL2 Mini DV Digital Camcorder
Cassette player is eating tapes
Hey there.
Cassette head cleaners generally only improve the sound quality on playback. This problem sounds more like something mechanical; I would open the player and check out the capstan and rollers. If they are dirty, clean them with a mild soap and water solution, (carefull to not get it too wet). Also, as for the tape deck in your vehicle, OEM systems are notorious for eating and destroying cassette tapes.
Let me know how this goes over,
HortonA!
Mar 22, 2009 | Audio Players & Recorders
Tape Drive is eating my tapes
Besides buying a new one, if you have the knowledge, you can try to open the tape drive and clean it from the dust it may have. You should also clean all the rubber roller's that thouch the tape (when it is inserted) with a cotton swab with some alcohol.
Oct 14, 2008 | HP StorageWorks DAT 72 Tape Drive
Camcorder Problem
Try cleaning the tape head first with a tape cleaner. If it continues look for any obstructions or foreign objects inside the tape deck.
Aug 31, 2008 | Video Cameras
Samsung VP-D103i Mini DV eating tape apon inserting
Have you cleaned the tape deck using a DV tape cleaner?
Jul 06, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
244 people viewed this question
 Grubhead
Grubhead
