Question about ASUS P4B266 Motherboard
Upgrade from 512MB to 1GB
I have an ASUS P4B266 MB with 512MB RAM which works well. I can put this RAM in slot 1 or slot 2. If I remove the 512MB RAM the BIOS tells me the RAM test doesn't pass. If I put the newly purchased 1GB RAM in either slot 1 or slot 2 nothing happens, the BIOS doesn't even call out any diagnostics. The specs for the RAM and the specs in the MB manual are identical, PC2100, DDR 266, DIMM, unbuffered non-ECC, SPD. The RAM spec is non-parity but the MB manual doesn't say anything about parity. Any ideas??
paul
  • 1 more comment
  • paulj1x Mar 15, 2008
    Thanks Brad. I've tried three different sticks, all with the same
    result. It appears to me that the BIOS never even gets started or
    crashes soon after it gets started. I've left the video card out so
    that the diagnostics will tell me that there is no video card, but it
    doesn't even get that far.
    paul
    Thanks BigZ1981. Yes, when I left the 512MB in and added the 1GB, the first time I powered on I got a CPU overclocking error (I think, the audio isn't very good), but on 10 subsequent power ons I got nothing. By the way, I'm not overclocking, and I do have SPD enabled in the BIOS.
  • paulj1x Mar 17, 2008
    I may have found the answer. I'm being told that this motherboard uses the Intel 845D chipset which only supports low density DIMMs, and the new ones are high density DIMMs.
    paul
Only 512 slot 1 then 512 slot 2 are only supported of your motherbord
Posted on Aug 14, 2008
  • 24 Answers
Have you tried both modules together? (leave the 512 in & add the 1G)
Posted on Mar 15, 2008
  • 46 Answers
The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
SOURCE:
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
Aug 02, 2013 | HP Pavilion ze4365us Notebook
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
I have 512 mg of memory. Would there be a big difference if I add a 1 gb stick and keep the 512 mb , as oppose to removing the 512 mb and replace with two 1 gb sticks?
The performance of your laptop will improve if similar memory is placed in each of memory slot.If 1gb memory and 512mb memory are placed in available slot you will only get the performance of a single 1gb memory.but two 1gb memory are used performance will be similar to a 2gb ram or more.
May 30, 2010 | Acer Aspire 3003WLCi Notebook
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
How do you install 4 sticks of ram? I have 2x 512mb and 2x 1gb. Do I put the pairs in the same color slots?
Yes, there are 4 slots, two colors....put the same ram configuration in the same color. RE: 1 GB sticks go in one color, 512 MB sticks go in the other.
Oct 25, 2009 | ASUS A8N-SLI Deluxe Motherboard
Hello, I have a Satellite A15 @129 w/756 MB RAM. I'd like to upgrade but don't know the maximum RAM stick each slot will take and don't remember if there are 2 slots or 4. Thanks, RD
The maximum RAM for this laptop can up to 1 GB DDR1 266MHz RAM and 2 memory slot available, so since u have already 756 MB RAM in your laptop, that mean 1 of your RAM stick is 512MB and another 1 is 256MB, so if u need to upgrade, u have to replace the 256MB with 512MB to make it 1GB maximum.
YBC (/\)
Oct 07, 2009 | Toshiba Satellite A15-S129 Notebook
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
I tried to install a new motherboard, and it is not working at al
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us This is a link to the new board you installed good luck send me more info and I WILL HELP MORE IF I can. Good luck.
Jan 16, 2009 | ASUS P4B266-C (P4B266-C WA) Motherboard
Hello My ASUS K8V-MX Motherboard has only two memory slot
Look into you're manual, go to pages 1-11 & 1-12.
The memory listed here has been tested by Asus to work correctly in the K8V-MX motherboard. In order for you to reach 2GB memory you will need DS memory. Double sided. This means there is 512MG on each side of a single DIMM, hence 2x1x 512MB DIMM equals 1GB. So you will need 4x 512MB to raxhl a total memory of 2GB. Please stay within the recommended memory listed on the Qualified Vendor List (QVL).
Simptronics memory it not on the QVL list. From time to time some memory not one the list may still function. This is not one of those times.
Mike
May 19, 2008 | ASUS K8V-MX Motherboard
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
ASUS P4B266 Motherboard Logo
185 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
