Question about Whirlpool Duet GHW9150P Front Load Washer
  • Jormaccoop Mar 15, 2008
    I had the same problem and then switched to Charlie's Soap (all natural) laundry detergent and the odour is now gone. Also, I don't use fabric softener at all anymore. Hope this helps.
  • Whirlpool Master
  • 2,651 Answers
Fear not there is new product on the market designed just for your very need. . but lets go over a few steps first. It actually for the most part ,not mold/mildew although it seems that way. First and foremost you MUST MUST use an HE detergent. not just less of regular detergent but actual HE detergent (and only 2-3 tablespoons of that even) Cut back on the amount of fabric softener that your using (if any) and leaving the door ajar between wash cycles improves air flow through the tub assy. Finding that its actually been a build up of extra detergent not breaking down completely giving of the odors. this product will help!!!!
Posted on Mar 15, 2008
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
My Samsung front load washer, which is about 1 1/2 old, smells like mildew. I've read that people put bleach in the drum and run it on a maintanence cycle and I'm wondering how I do that. ...
I had this problem too---same washer. The rubber door seal often harbours moisture and it's hard to clean just by running a cycle. You'll have to scrub away the mildew by hand.
Get a pair of gloves, a soft sponge, and a bucket of hot water with soap and bleach. Open the door. Press the sponge into the folds of rubber where the moisture is trapped. Work your way around the circumference of the seal. Repeat until the black goo is gone. Finally run a rinse cycle with some bleach.
Avoid this in the future by leaving the door ajar when not in use. Tuck an old towel into the seal to wick away the water.
Let us know if the smell is still there.
May 20, 2011 | Samsung WF337AA Front Load Washer
How do I get rid of a mildew odor in the Whirlpool Duet front loader?
bleach and bleach and bleach and bleach!!!!! also i notice more of a smell in washers when people only use liquid detergent and too much of it.
Tip: leave door open after every wash
clean with bleach and hot water regularly once a month
with no clothes on a normal cycle
alternate liquid detergent and powder (yes powder comes HE)
only use HE detergent
try these things and you will find your washer smelling like new again. but tthe trick is BLEACH and a lot of it. once you get a smell it takes a long time to get rid of it.
good luck and let me know if this helps
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the issue with mildew and how do I address it? My laundry never smells clean
Any washing machine will grow mold & mildew when there is moisture in it and the door is shut. When you do a load of wash, the smell transfers to the clothing. To eliminate it, run a load just water & chloring bleach. This will kill the spores. Adding a little color safe bleach to each load or leave the door open when not using the washer will keep the problem from coming back.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My wirlpool duet front load washer stinks both when in use and not in use. how do I thoroughly clean and fix.
Is the odor simular to mildew? If so do you leave the washer door ajar after use? If not you should, it helps promote air circulation and helps dry out the inside preventing mold and mildew smells. I would run the washer on sanitary cycle or hot water cycle with bleach and baking soda. Then leave the door ajar from then on.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Strong mildew odor in Duet washer
are you useing he detergent? if not this is your problem the washer cannot get ride of the soap so what it does is leave a layer of film in your washer and odor causeing bacteria forms in it. There is a product called AFFRESH you can buy it at SEARS it is made specifically for this. Do you leave the door open ragularly? The reason I am asking is because your washer is like your bathroom if you do not ventilate it properly it will grow mold and it needs to be cleaned. By leaving the door closed all the time it is very easy for the bacteria to grow.
So my advice is to leave the door open, make sure you are useing the correct soap (HE) high efficiancy soap, clean the washer with no clothes hot water and bleach and use the affresh or washer magic. Since you can smell the smell you are going to have to keep cleaning it abouit 2-3 times a month till it goes away. Then once a month. This is not a machanical problem or a whirlpool problem and is very commen in ALL front loader if you do not clean it regularly.
Jun 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell
Are you useing HE detergent? If not this is your problem! The reason why you need to use HE detergent is because it is made specifically for front load washers. The regular soap is made to be deluted in 20 gallons of water your washer only fills up with about 7. so what it does is it leaves a layor of residue SINKY SINKY. Especially when you leave the door shut all the time. It's like a Bathroom if you do not ventilate it properly it will Sink eventualy. So also please leave the door cracked open.
So to getr ride of the smell Sears sells a product called Afresh or Washer Magic I prefer the Afresh you get 3 tablets and it works great atr removing odors out of your washer. Also if you are on a Well wateer it is safe to use. Or you could use good old bleach with no clothes till the smell goes away
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front load washer smells!
Did you check for small wet items just inside the door? Push in on the soft gray rubber area right down in front and made certain you don't have something soured down in that area.
Dec 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Smell, mold , and mildew
Do you always leave the washer open? We've never had this problem but they told us to always leave the door open slightly whenever it's not running.
Sep 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
208 people viewed this question
Dan Webster
Dan Webster
Sal De
