SOURCE: Front air condition does not blow cold. Rear air condition does
sounds like a damper door in the front not working properly, these are actuated by the front temp control, the door is operated by either a manual cable, and electric actuator, or vacuum. I hope this helps you zero in on your problem. Merry Christmas
SOURCE: air condition blows hot air but it has freon
You may have created an over charged condition and at this point the a/c compressor will cut off on high head pressures. This can be verified by installing gauges to the systems high and low side service taps and reading the pressures.An overcharged system will start the compressor briefly but soon cuts off once pressure goes to 350 - 400 lbs on the high side. Acceptable pressures for this system should be no greater than 250 high and low suction should drop to 40-50 psi.You might recover the charge and evacuate the system,then try bringing the charge back to proper level.A sight glass in the reciever drier really helps determining proper fill.Once all bubbles have dissipated from the sight glass during charging ,one should stop at that point to avoid overfilling.Too much freon is worse than a low charge especially in hot ambient conditions....
SOURCE: 2002 GMC Yukon blows cold air from the front, rear works fine
check you antifreeze level and make sure its full
