Question about Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive
How to fix hard drive that's not appear in window but seen in bios
Good day to every one!!
can anyone help with this problem??
I have an old seagate 40g ide hdd i cannot format it using ms-dos or even in the win xp its not appearing on My Computer.. but seen in bios set-up.
Can anyone help on how to fix this? plss.
  • jun_888 Mar 17, 2008
    thank you sir I'll do that
  • Anonymous Apr 18, 2008
    How to fix hard drive 80 Gbytes that`s not appear in my computer
    My E-mail : [email protected]
  • 46 Answers
You can use a more sophisticated partitioning and formating software program such as GParted or Acronis Disk Editor. Both programs can create a bootable cdrom that will boot and allow you to delete create and format partitions.
gparted: http://gparted.sourceforge.net/
acronis: http://www.acronis.com/
good luck!
Brad Nelson
Posted on Mar 15, 2008
SOURCE:
I have a seagate momentus st94q19a 40 gb hard drive from an old netbook. When I try to install Windows XP, it tells me it can't access the hard drive. Is there any way to fix this or is this hard drive...
see if the BIOS setting for the hard drive is se to IDE. Then, see if there are any jumpers on the hard drive. There should be a diagram on the drive itself that you can follow to place the jumper as Master, or just remove the jumper.
Also, you may want to test the hard drive for surface problems before you make it a system drive. Usually system hard drives go through thousands of read/write cycles that wears them down quite fast, so if the hard drive works just fine as an external USB drive that doesnt mean it will do good as system drive.
Dec 21, 2010 | Seagate Computers & Internet
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Seagate Cheetah ST3146854LW hdd does not startup--appears dead
Your drive may be Dead On Arrival. I would contact where-ever you purchased it from and ask for a replacement.
Jun 19, 2009 | Seagate (ST3146854LW) 146.8 GB Hard Drive
No icon showing in My Computer for slave HDD
On XP computer install your seagate barracuda 400g. start the computer. when xp is already boot right click My Computer then select manage. When Computer Management dialog box appear click disk management. Look for the drive that is unallocated and format the drive and follow the instructions.
Feb 17, 2009 | Acer Computers & Internet
HDD Has been stop be detected in my computer,PLZ HELP!!!Somebody!
try plugging the hard drive into the other ide port on the motherboard
Oct 27, 2008 | Seagate Internal Hard Drives: ST3160021A...
Mixing ide with sata
Maxtor now owned by Seagate are having a number of issues with current tech, most of the time you can down load a flash for the firm ware, but there are those times that it will not work. If you had information on the drive you will not be able to retreive it unless you go through i365 a seagate company. depending on how much info you have on the drive they will charge anywhere from 400.00 - 1300.00. To this day they simply just do not provide the programme required to access the drive, I know I am going through it now..
Sep 24, 2008 | Maxtor (L01P080) 80 GB Hard Drive
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Corrupted Program
when you reboot, go through F2..and see what's showing there first..
Mar 21, 2008 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Hardrive Partition Is corrupt
As i review your explaination, there might be a problem in your hard drive. There so many problems i encountered in the hard drive i encountered like that. However, some problems can be fix using your solution and the other can be fix by replacing the BIOS Battery, and sometime the error in the hardrive is cause by a memory fault. If you are sure that the memory, motherboard, and the bios battery is good and working properly. I recommend you to replace your hard drive that the inconsistency problem will be fined.
Please do testing of your hard drive by connecting it to the other system.
Feb 01, 2008 | Seagate (9W2041-337) 40 GB Hard Drive
Seagate HDD 40GB 7200RPM ATA100 2MB (ST340014AP) Hard Drive Logo
125 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
