Question about HP Pavilion dv4000 Notebook
Booting my system does not boot, repair, recover, or even format says it cant find the hard disk and when i put it on it gets stucked at the 'windows pls wait booting sign' pls help
  • 377 Answers
Dear one
you have already used the HP Operating CD to set up your hard drive (and formatted your hard drive, and installed XP, and installed the drivers, and really don't want to do that again), you can still “fix” the partitions - as long as you have the space for Quickplay outside the XP partition.
1. Boot from you HP operating system disk.
2. Press ENTER to set up Windows XP
3. Press F8 to accept License Agreement
4. With your XP partition highlighted (it’s usually C:) press Esc.
5. Make sure you have at least 250MB of unpartitioned space after your XP partition. (If you don’t, you probably have to delete XP and start all over.) I had to delete the 204 MB partition I created in the first place.
6. Once you have your XP partition and at least 250 MB of unpartitioned space, press F3 to quit. (Don’t mess with the XP partition!)
7. Press F3 again.
8. Remove your HP operating system disk.
9. If you’re really fast, you can stick your Quickplay disk in before it reboots. Otherwise, let XP load, put in your Quickplay disk, and restart.
10. Quickplay should load successfully.
11. Note that when this is done, Quickplay will actually only use 204 MB of the space after your XP partition. It just needs more than that to actually run I guess.
Posted on Mar 15, 2008
I want to know how to reinstall toshiba portege m200
This is in case you cannot boot into windows but you can get into bios:
Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer.
If you can get to the stage where you can see see bios entry key then keep pressing whatever key it is that you press to get into bios at start up.
Select the option that let's you choose the drive to boot from, mine is in advanced bios options. then go to either something like bios features or change boot whatever drive represents your CD-ROM drive and select it to be the first boot drive.
then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive.
This will let you restart your installation of windows and
re-format the drive...
If you can boot into windows:
Then either re-format the drive and delete the partition when you do or...
Run a recovery of the system by installing your disk and letting it get to the stage wher it asks what action/task you want to perform and press r when prompted then follow the prompts to repair the files. This might not work though,
you could even try running a disk check as maybe a lucky chance of repair if you can get into windows.
If your PC keeps trying to boot from the CD drive after repair then re-enter bios at start up and change your hard drive back to first boot device to boot into windows.
It's better if you re-format though as repairing windows can be a little tricky.
Aug 01, 2011 | Toshiba Portege M200 Tablet PC
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
A boot disk (startup disk) and why you need it?
The Windows installation disc contains the files necessary to start Windows, so it is itself a boot disk. A boot disk is actually not a computer disk in the shape of a boot. If it was, most disk drives would have a difficult time reading it. Instead, a boot disk is a disk that a computer can start up or "boot" from. If a problem is preventing Windows from starting, you can use the installation CD to start Windows. The installation CD also contains Startup Repair, which you can use to repair Windows if a problem prevents it from starting correctly. Startup Repair can automatically fix many of the problems that in the past required a boot disk to fix.
A boot disk (sometimes called a startup disk) is a type of removable media, such as a floppy disk or a CD, that contains startup files that your computer can use to start Windows. CD and DVD boot disks are often used to start up a computer when the operating system on the internal hard drive won't load.The startup files are also stored on your computer's hard disk, but if those startup files become damaged, you can use the files on a boot disk to start Windows
Earlier operating systems that used the FAT or FAT32 file systems, such as Windows 95 and Windows 98, a boot disk was especially useful because it allowed a person to access files on a hard disk even if Windows was unable to start. This ability also represented a security risk, because anyone with a boot disk and access to the computer could start the computer and access any file. Hard disks formatted with NTFS have built-in security features that prevent using a boot disk to access files..
Let looks at some useful "boot CD downloads" to create one for Windows OS,s.
1-Ultimate Boot CD for Windows - This BartPE-based boot disc comes with a huge selection of tools to access your data and get your PC booting properly again. Some of them are even useful.UBCD takes a long time to load and asks you some odd questions before it's finally up. But once it's there, you can edit the Windows Registry (yes, the one on the hard drive) in RegEdit, recover deleted files, and even run benchmarks. setting up UBCD is identical to creating a BartPE disc--with the same possibility of failure. But when it works, you get a lot more.Price: Free
Download Ultimate Boot CD for Windows.
2-Puppy Linux - A third party application to create a boot CD using Linux and great for accessing NTFS-formatted hard drives--especially if you're not comfortable with Linux's whole mount concept. Just open the Drives window and select a drive, and Puppy will mount it for you--in read/write mode, if possible.Puppy will mounting the drive with read/write permissions and you not only can copy your files elsewhere, but you can also edit them. Puppy Linux comes with AbiWord, which supports .doc files, and Gnumeric, which supports .xls. And even if it mounts read-only, you can still copy the files to an external drive, most of which are formatted in the universally accessible FAT32 file system.
But be careful how you click. Actions that take double-clicks in Windows, such as opening a file, take only one in Puppy.
Price: Free
Download Puppy Linux.
3-BartPE - The BartPE operating system makes a pretty good boot disc on its own, getting you into Windows and letting you access your drive. It doesn't have much in the way of repair utilities, but it has chkdsk, which should probably be the first one you try.To create a CD, the program needs the Windows 2000 or XP installation files. One place you're sure to find them is an actual Windows installation CD-ROM. But the recovery disc that came with your PC probably doesn't have them.
Luckily, if your PC came with XP installed (and thus, not with a true XP CD), the necessary files are probably in a folder called C:\Windows\i386. But I do mean probably, not definitely. However, since the PE Builder is free, you're not losing much if it can't create a disc.
Price: Free
Download BartPE.
4-Vista Recovery Disc - a unique distribution of Microsoft's own recovery tools.This Recovery Disc is basically a Vista installation disc minus the install files. It even has an "Install now" button that asks for a Product Key before failing. You're better off clicking the Repair your computer button. Among its Vista-only options are a tool for diagnosing and fixing startup problems, a version of System Restore that uses restore points on the hard drive, the restore portions of Vista's backup program, and a memory diagnostic tool. Price: Free
Download Vista Recovery Disc.
5-Trinity Rescue Kit - TRK's command line interface could humble anyone but the most devoted Linux geek.
If you take the time to read the 46-page documentation and learn the program, you'll be rewarded next time disaster strikes. Among the tools that will be at your disposal are a script that runs 4 different malware scanners, a tool for resetting passwords, a Registry editor, a program that clones an NTFS partition to another PC over a network, a mass undeleter that tries to recover every deleted file on the drive, several tools for recovering data off a formatted or dying disk, two tools for fixing master boot record repair programs, and hardware diagnostics.
Price: Free
Download Trinity Rescue Kit.
Hope that you understand the benefits of having a boot disk on your wardrobe.
on Jan 04, 2011 | Computers & Internet
I just upgrade to Win 7. Now everytime when powering up the machine, there are two boot options like this: Previous Windows Operation System Windows 7 (with Windows 7 highlighted) Of course I...
If I understand you correctly you had a previous operating system installed on one hard drive and you just now installed Windows 7 but on a separate drive? When you boot the machine if gives you two boot options, the old OS and the NEW OS?
What your going to have to do is format the drive(erase) that contains the old operating system. Format as NTFS.
Try unplugging the old drive, making sure the new drive is set to master and not slave. Boot up the computer.
When you boot up your computer you should immediately get options. One of these options should say "press delete for bios" or press "f6 for settings" You need to go into the bios and make sure the drive with Windows 7 is set to your primary drive in the boot order(hard drive should be first in boot list). We want the computer to boot to the new drive first.
Once you get into Windows you can use a program like partition magic to format the old drive to use as just storage space. You can even use "diskpart' which is an old windows command line utility.
If you reinsert the Windows Disk when you are booting up you will get some recovery options, and if I recall correctly one of these should let you format hard drive space. So, you may be able to do it from there.
Where exactly does the error come up in the boot process? Are you able to boot into safe mode? It may be easier for you to just reinstall Windows 7. If you boot the computer with the disk in the drive, and the BIOS set to boot first to the disk, then during the installation configuration you should be able to have Windows just format the old drive to use as space and install the MBR on the new drive.
Jun 11, 2011 | Microsoft Windows 7 Ultimate for PC
Re: R400 stuck at ThinkPad screen wont boot
Computers always boot from the hard drive.
The Bios on the mother board have a routine that tell it to boot from the Hard Drive, or USB in the BIOs setup.
to look at the BIOS setup, when you turn it on keep pressing the <ctrl><alt><del> keys on your key board, this should let you go into BIOs setup. there you can check which device it the first boot, second boot and third boot.
If your hard disk the boot, it is probably crashed, you will have to take it in to be repaired, and you might need a new hard disk.
in which case the repair shop will have to put in a new hard disk, format it as bootable, then reload the operating system, and any software you might have been using, so take into the shop all cd software disks with the computer to the shop so they can reload all your stuff. If there were any files you had on the disk, they may or maynot be recovered.
Good Luck...
Nov 11, 2010 | Lenovo ThinkPad R400 Notebook
Windows XP won't boot
try repairinf the system with XP cd..or if it fails then format and install a fresh copy of XP...
Mar 27, 2010 | Microsoft Windows XP Professional for PC
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
PC halts while formatting hard drive
make sure your hard disk is error free Try formating the disk with FAT first ,if it doesn't work out the try disk utilities .
Nov 29, 2007 | Microsoft Windows XP Professional for PC
Invalid media
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 22, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
HP Pavilion dv4000 Notebook Logo
137 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
