Question about HP Pavilion dv4000 Notebook
Hard disk my laptop hard disk is given me a click sound, i want to know how to fix it. without buying a newone. because right now i have a collection of laptop harddisk from other pple and they all have the same problem i need some professional help
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    clicking? as in a ticking sound, or some vibration?
  • 46 Answers
Generally a ticking sound indicates a faulty hard drive. If you can access your data, i suggest you back up your data as soon as possible.
there are several possibilities that cause the ticking such as:
1.) The clicking sound appears to only occur when the drive is idle. Forcing the drive to be busy silences the ticking while the drive is busy.
2.) repeated attempts to spin up the platters
3.) The ticking sound comes from the hard drive is caused by repeated attempts to find track 0.
if your noise occurs from solution 1, then I would'nt worry about the noise. However if its caused by problem 2 or 3, then I would backup data and purchase a new drive.
Hope this helps!
Brad Nelson
Posted on Mar 15, 2008
Recently my external hard disk freezed. i connected to one of my friends laptops and once it was visible and accessible. next time, it was not accessible visible though. I thought it is the problem of his...
i would check the image you have saved before formatting your external drive just to make sure you will have it after a format you will lose all data
if you can see your external hard drive
right click on your external drive select properties tools check now you should check now with two boxes you could tick both boxes automatically fix files and attempt repair bad sectors on your drive
have no input while chkdsk utility is in progress any may damage this external drive
also
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope some of this helps you
Sep 23, 2011 | Seagate 500GB FreeAgent GoFlex Pro
Tip
How to detect if your hard-drive is working or not/hard disk maintenance.
Some times you don't know if your hard drive is working or not. Your external hard disk might drop on the ground, or your desktop/laptop hard drive might not be booting. Which ever the case maybe, here is how to find out the condition of your hard disk:
Put your ear close to your hard disk, if you hear your hard disk make a crackling noise, be prepared to buy another hard disk because such hard disk is damaged and cannot be fixed. Also note that it is difficult to recover files from such hard drive.
But if you don't hear a crackling sound, use your hand(s) to feel the drive, if it vibrates, it means the hard disk is in good condition.
What damages external hard drive most times is if you don't eject (safely remove) it from your computer, when it drops on the ground or hits any hard object etc
If your external hard disk stops working, firstly, check if the hard disk inside the case is in good condition by checking for crackling sounds and vibration. Once you observe that the hard disk is in good condition, this means the hard drive case is defective/the cause of the problem. Get another drive case and your drive will work again without loosing any file/data on it.
For desktop/laptop hard drive maintenance, make sure you always shut down your computer properly, don't remove the CPU's power cord while the computer is turned on. To be on a safer side, always use UPS (uninterrupted power supply) for your desktop computer.
Also, when using your laptop, makes sure its fixed at a position. Avoid any shake as the hard disk might shift from its normal position in the process.
Good luck.
on Oct 21, 2010 | Computers & Internet
The start up was loading and it is slow..and my friend said that the hard disk of my netbook is the problem..what will i do?
The slow start can be a caused by the processor speed, ram, graphics, bios, many things can cause it to load up slowly if your friend thinks its the hard drive without physically hearing the sounds it makes then its probably is, i would recommend you buy a new hard drive for your laptop and installing your operating system depending on how big you want the hard drive to be can be a bit expensive getting a hard drive with at-least 2-4 meg cache will greatly speed it up too.
Jun 29, 2011 | Computers & Internet
When i switch the laptop, i hear a knocking sound from hard disk and the computer displays non - system disk or error disk plz help
Good Day Kawindwe!
I am sorry but I think the hard disk is on its last leg. A knocking sounds is the first symptoms of faulty hard disk. It is better to replace it.
The non-system disk error is displayed when the CMOS BIOS failed to detect the hard disk.
There is a small chances of making your hard disk work again. It worked for me before maybe it might work with you too.
First, turn off your Laptop. Remove the power supply adaptor from your Laptop. Remove the battery. Press and hold the power on button for at least 5 seconds to discharge remaining volts on your unit. After awhile, return the battery, plug in the power supply adaptor and turn on Laptop. See if that recognize again your hard disk.
If the first did not fix it, try this one. Turn off your Laptop. Disconnect your hard disk and then reseat the connectors properly. Then, turn on your device. Did that fix your problem?
Kawindwe, in case that fixed it, I recommend you back up your files cause the hard disk will not last that long.
Jun 10, 2011 | Computers & Internet
I have a Samsung 3g 2tb harddisk and it makes strange noises. sometimes it doesnt work and a my pc freezed.
Here is what you need to know about hard drives.......
I hope this is helpful..........
Good luck.
Mar 07, 2011 | Samsung G3 Station Desktop External Drive...
Wd my book flashing blue light. sill no power up
Good luck.
Jan 22, 2011 | Western Digital My Book Essential 1TB...
Hard disk tiking when power up.
Good luck.
Jan 11, 2011 | Hitachi HTS542520K9SA00 200 GB SATA Hard...
Help
Unfortunately it sounds as if the hard drive is clicking and not detecting because it has failed. At this point you will need to locate the operating system media for your system and purchase a new hard drive and start from scratch.
Jun 17, 2010 | Sony VAIO VGN-N250E/B Notebook
My laptop makes a clicking sound every so often and the freezes.how can i stop this
This is a hard disk issue, there are a lot of bad sectors on your hard drive. I would suggest you to buy a new hard drive, because it is a very difficult job to fix it.
But still you can watch this video and decide if you do that much hard work or you'll just go buy a new cheap hard drive.
Click Here to Watch the video.
Hope this helps.
Apr 07, 2010 | Acer Aspire 5315 Notebook
Cd player, wi fi audio hardware disabled
If you own the computer why has he prevented you from accessing all the features of your computer and not given you administrator rights?
You should demand him to fix this.
Otherwise collect your disks including the Windows XP or Vista install disks and take it to another computer repair shop or a tech savy friend to reinstall Windows for you.
Mar 05, 2009 | HP 530 Notebook
HP Pavilion dv4000 Notebook Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
